drewpy
Everything posted by drewpy
  1. drewpy posted a topic in Yamabyss
    I went to a Roger Moore/James Bond party last night, and for a laugh I went as Sean Connery. It certainly raised a few eyebrows.
  2. dana
  3. big bore doesn't always mean higher rpm as there is more reciprical weight to throw up and down in the bore. if anything it would be safer to keep the revs down rather than risk blowing up the engine!! I know 50cc racers get to 18,000- 20,000 rpm but that is for 1 race
  4. you've not met Goff yet though......................................
  5. drewpy replied to grahamj's topic in The Bar
    to the forum XS400's rule!!!! mwahahaha
  6. drewpy replied to workingman's topic in Classics
    what carbs are on those mikuni or hitachi?
  7. rich B hope this forum will enlighten and amuse you and maybe get some sage advice from OldGit (OG)
  8. with magneto it should start without a battery, but the lights/indicators won't work properly or not at all. well that's what i did on the wifes cg125 (who is slowly coming round to liking the bike!!)
  9. we need dates, maybe do a poll to get an idea for numbers!!
  10. I got an XS400 front cast wheel NOS. Its done only 2k till i changed to wires. PM me if you are interested as I think they fit the RD's as well!!
  11. drewpy posted a topic in General
    some amazing and disturbing photographs from news agency http://www.boston.com/bigpicture/2008/12/t...tographs_p.html
  12. drewpy replied to Chalkmyster's topic in Yamaha Workshop
    without any more details like year etc try here http://www.cmsnl.com/search.php?s_name=YZF+
  13. 1982 12E (should be the same as 83 as no more codes) chassis #'s 000101-100000 12E 000101-100000 Super Red abbreviation SUR paint code 2U
  14. in the last classic motorcycle mechanics you can make one out of a G-clamp and a castellated metal tube welded on the flat part (to get the collets out) I'm sure theres something similar on 't web
  15. If you have an old Gs you HAVE to have them on or your alternator gets fried (overheats)
  16. drewpy replied to DHtri's topic in Yamaha Workshop
    my front wheel doesn't rotate either
  17. its not an accronym its latin
  18. drewpy replied to lison766's topic in Classics
    PJ! is the best comes in satin or gloss black for engine cases. they are petrol proof when cured!!
  19. take it easy there, make sure your tyres are in good nick and at the correct pressure. fitting a big bore will invalidate your insurance (as may a taller gear) and make sure your license is valid for a motorbike. (I sound like a boring boring old fart (ergo OG))
  20. Hallo and to the site
  21. just recieved notification the the Barnsley motorcycle festival date is the 21st June 09. A great day out and you get to "parade" your bike around Wombwell Kart track. you never know, OG might ride his bike on it this time? http://www.freewebs.com/show-with-go/ with pictures and videos even got yours truly racing racing round (7th from bottom; line 1; on first page, 2008 photographs)
  22. drewpy replied to HoggyF's topic in Yamaha Workshop
    the problem with just tightening them up is that the end might puncture the inner tube. you will need to take the tyre off, then you can tighten them till they "ring" the same as the others, then check for trueness by spinning the wheel with a marker near the rim for visual confirmation.
  23. drewpy replied to robbieglasgow's topic in Yamaha Workshop
    is there a fuel smell on the spark plug? you could always throw a bit of fuel in there to see if it sarts up and if it does the carb is blocked (or the petrol tap is switched off) if you can get a run with a bit of fuel in, knock off £50 at least as its a pain getting the carb cleaned if you don't know what you are doing!!
  24. yep too agressive and you'll get a black eye!!
