drewpy
Everything posted by drewpy
  1. will do, i got a paddock pass
  2. drewpy replied to jonnyruk's topic in The Bar
    motorcycle and reinforced?
  3. drewpy replied to steve 46's topic in The Bar
    have you tried event tyres? they come round and fit then too
  4. where's the bath tub side car?
  5. drewpy replied to drewpy's topic in Yamaha Workshop
    I found the xs400SH was 170kg and the xs400H 167kg, 400E 168kg, 400 2-e 155kg, 400f 168kg, 400-2f 159kg, 400sg 169kg and 400g 166kg from the yam service manual. good info on the model range Jim. I used the 250C wires for my 400
  6. drewpy replied to janey-G's topic in The Bar
    Janey G,
  7. drewpy posted a topic in Yamabyss
    I forgot to wish everyone a happy star wars day yesterday May the 4th (be with you!)
  8. drewpy replied to russ500's topic in Yamabyss
    mines "excess"
  9. the reason I stick with classic bikes is that they are a hobby and although I use my car for commuting ( shitty m60 at whitefield and death valley) I manage to combine both reasonably well. winters gets me rebuilding/messing/talking bikes so I'm still in touch and my friends basically do the same!! so I'm out on the bike when the weather is good and in the car when its shit!!
  10. drewpy replied to CadXS's topic in Classics
    as far as the front is concerned no problem. the rear will need the pedal and linkage to operate the rear brake
  11. er, have you switched off the cut-out switch by accident?
  12. drewpy replied to drewpy's topic in Yamaha Workshop
    far as I know the weights refer to the standard models. and there were never an SE option on the 360!
  13. nice bike and a good job G-man I like the yellow
  14. drewpy replied to drewpy's topic in Yamaha Workshop
    I thought all 360's were drum braked, thus wired!!
  15. drewpy replied to drewpy's topic in Yamaha Workshop
    2kg 250 166kg 360 159kg 400 164kg I recon the 360 weight saving was in the wire wheels
  16. yep I can see it now. I thought the 360 had the same carb as the 400 but it has the O ring like the 250 carbs
  17. drewpy replied to bigpete's topic in The Bar
    did you undo the black earth?
  18. drewpy replied to bigpete's topic in The Bar
    yeah, good one I think foamy appreciated it!!
  19. drewpy posted a topic in Yamabyss
    I've just met a deer who could write with both his left and right hooves. He said he was bambidextrous.
  20. drewpy replied to joe stokes's topic in The Bar
    Joe. its usually a centralising spring situated on the opp side of the gear lever. (casing off I'm afraid) I'm sure Yamagod will have a manual for you to peruse
  21. drewpy replied to rawiswar's topic in Yamaha Gallery
    sweet ride to the forum
  22. nice bike, will you ever finish it or are you gonna keep modding it?
  23. vetter was the godfather of fairings and designed the BMW stuff in wind tunnels
  24. great, get to post this of OG again I'm not too sure this is your problem though!! I think its from your gas cap and by turning the key you may just conicidently shake the tank and the petrol fumes just escape due to the disturbed petrol. check its not partially blocked, or try it with a loose gas cap and see if happens again?
