Everything posted by drewpy
Upgraded xs400 to Electronic Ignition
just connect and see, it won't do any harm as the sparks will still happen just at the wrong time. I do it all the time and never bother writing down which is which.
Fuel Petcock
the pet cocks are easy enough to repair as you get all the gaskets etc and you keep the originality of the bike if its well looked after! I would def need mine as I forget to take my keys out of the ignition never mind switching off the petrol!!
- Headlight
XS400 speedo lights burnt out, apparently
its just rubber holding them in, so gentle tweeks are in order and they should pop out!
another xs400 start up
nice view of an XS400 cup near the end this bike is freekin LOUD ">" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525">
- REMEMBER
xs400 tracker start up
exactly the same engine except for bore, valves and carbs btw please start a new thread as its
xs400 flat tracker project
the seat is off the shelf an XR750 replica I belive try hot wing glass or omars for these sort of things
'79 Suzuki GS 1000S restoration
that bike is amazing, god find djcrow
81 xs 400 Clutch issue
impact driver with a tight fitting allen key or basj on an over size star/torx key
hey, they're called ice cream legs, coz girls want to lick them when they're HOT!! its stock wiring which i am taking out all the unessary bits coz I'm running with ignition, brake light and horn and that's it. minimum for the MOT
FS1se (FS1e Chop) Forks
at the top of the fork slider there should be a collar which unscrews. you can see it better here
Maxim/Seca Main Jet Size
there was two different types of dohc xs400, 36hp and 45 hp you may have the 36hp one.
i'd check the worm gear on the clutch cover is not broken. its only plastic and I'm not sure how you can break a 200lb breaking strain cable unless its rotten!!
The Junction Function
unfortunatly i am going away weekend with the family. Did you get rock radio to advertise it, i think it is free if you go on the website!!
dem links don't work for me!!
not really, could'nt hear them anyway
What do we have??
what says AT1 - 171537, the chassis number?
started off as kenny roberts modified xs650, then the idea grew from what was around. I get sideburn magazine which captures the spirit of the bikes, and also this..... on the mile long tracks they are on 120mph and 8o round the bends.
Another tire thread...
I've got the maxxis 3:50 on front and 4.00 on rear. for the flat track look I don't think I could go bigger on the rear check out the end my flat tracker thread in the street bike section for the tyres. bear in mind the bike is slightly raised by 2"
goffs wedding tunes
Wow that's some writing Bark!! love the choice of music
">" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"> thought I'd start it up as I have just upped the mains to 135 from the DOHC'c 125/127.5 runs a lot better now as you can hear, but its bloody loud and next door came out saying "Oh you got another bike?" hmm nice quiet engine as well (compared to the exhaust )
Moon walk 1
oh so disco very is discovery, yep i saw it. just couldn't understand what you were saying
82 XS400J Oil Press. Lite not working
but if you have an earthing issue ie the wire from the switch is earthing out, then you will have the symtoms you describe!! what about the bulb and holder itself? have you checked that (replace bulb in case its an intermittent fault)
XS 400 carb issues
glad to hear you got it sorted pretty easily, well done!
