drewpy
Everything posted by drewpy
  1. no where near, 650 engine is taller.
  2. drewpy replied to jamax's topic in Yamabyss
  3. or DAZ or OMO or Persil
  4. yep, battery and flooding, that'll mess it up and even if the battery has 12v, the amps may be gone. happened to mine in the pissing rain, it started missing and wouldn't run over 50 mph. new battery and voila!!
  5. youth of today eh!!!
  6. you'll need a good amp charge to turn over the bike and run the CDI. get your battery amps checked or buy a new one as I think yours is on its way out!!
  7. drewpy replied to the doc's topic in Classics
    you don't need Lead Replacement Petrol, all jap bikes from the 70's were designed to run on unleaded. As OG said check filter and vacuum petrol tap. you would be well to strip those carbs and give the bike a good service. Also coils can break down after a bit due to their age.
  8. re-enforced concete is very strong
  9. so long as you ask them to supply the jets for a 250, can't see why not
  10. drewpy replied to mooch's topic in Classics
    will this one do? here try yambits site as well
  11. why? coz you always leave late, as you come too quick
  12. it tumbled like a matchbox? never seen matchboxes tumbling so i couldn't comment
  13. drewpy replied to jaydw's topic in General
    there is a site here and here
  14. voodvale rally is on only stunt bikes but loads of petrol head stuff like this
  15. good tip. some people melts tie wraps into the crack to weld a repair
  16. ebay uk has remanufactured fuse boxes for sale. you just need to get another connector to rewire the bike. ebay
  17. did you mix up the coil connections with the points. try switching them round. don't forget LT/RT is TDC for valves and LF/RF is for checking timing (contacts begin to open)
  18. maybe the battery is on its way out and the starter sups all the available juice so the ignition gets starved. its just you said that it starts ok on bump
  19. damn you beat me to it!!
  20. drewpy replied to rrau's topic in Classics
    coil heating up and going bad?
  21. glad your making progress. I think its a matter of ensuring you can brake ( new fluid every 2 years!!) and that the engine has good oil and is tuned up. start collecting tools as you can afford them ( even second hand) strobes are good for timing and vaccum gauges for occassional carb balancing ( go halves with someone) drewps
  22. I would say that's an after market exhaust as original yams were welded. I would go ahead and do it but don't over do it as you'll strangle the performance
  23. not sure, if its cheap enough try it as Rassk rear sets cost loads
  24. if its like the xs400, you need to drain the oil out and take off the right cover. than dismantle the gear selector parts and slide out the shaft. I bought a new one from yambits as its the same as an RD400 D/C
  25. drewpy replied to mooch's topic in Classics
    I would have though this site to be your best bet http://www.fs1e.co.uk/
