drewpy
Everything posted by drewpy
  1. drewpy replied to fightered's topic in The Bar
    to the YOC
  2. drewpy replied to devildfor's topic in General
    baz. enjoy your R6 ( but don't go too daft)
  3. langers
  4. if its a spoked wheel, you can get a new rim laced onto the hub. try central wheel, brum or wyldes in leeds
  5. a newb sent a report message to the mods, so here is nickson's message 1w 681 j resistor mark make of it what you will
  6. from the exhaust it could be flooding of the carb. mine did/still does that,(another job on the to do list) burnt oil is blue in colour. there realy should be a seal around the header as no smoke should be comming out there, so i would get new gaskets.
  7. I wonder if the headlamp relay is faulty and causing a drain on the electrics?
  8. drewpy replied to lison766's topic in Classics
    don't forget to cure it in the oven, otherwise it won;t be petrol proof and can chip easy!!
  9. have you felt the weight of the xs alloy wheels? they weigh a ton. i spent lots of money converting to spokes (although I do have disk brakes) drewps
  10. drewpy replied to up.yours's topic in Classics
    might have to bush the lever hole as it will have worn oval. needs drilling round and someone to make a bronze bush! or buy another one from yambits, hvc or PGM drewps
  11. drewpy replied to YMF's topic in The Bar
    adam
  12. i thought creamy goo is what mothers find in teenager's beds!!!
  13. the "hanging" of revs is down to gummed fuel in the pilot system, you may be able to tweek the pilot screw richer.
  14. use thread lock, normally the bolts already have the thread lock on then like this
  15. just comming back from Austria with the scouts, so I might have to give it a miss.
  16. cool, keep us posted in the classic section drewps
  17. to the YOC steve-0
  18. drewpy replied to James Roland's topic in The Bar
    james
  19. get your carb kits from siriusonic
  20. or float height has changed. try running some fuel cleaning additive through the tank to see if it helps
  21. what i meant was take up the slack and feel a little resistance, then swing. some folk just put a foot on the kick and wack it through putting undue strain on the system. the cg125 i got had a snapped kicker.
  22. drewpy replied to blackhat250's topic in The Bar
    bet that'll cost you an arm and a leg.......leathers, helmet etc
  23. drewpy replied to Panheadjosh's topic in The Bar
    PHjosh
