drewpy
Everything posted by drewpy
  1. drewpy replied to felix's topic in The Bar
    whats wrong with the http://www.xs400-forum.de/ site? there are sites within yahoo groups, but they are no good. why do you want an american site felix?
  2. or thread lock/spring washer
  3. drewpy replied to steg's topic in Naked
    if you have the money to burn why not!!
  4. thnks for the link
  5. first question is, why do you want to go for a disk conversion
  6. still listed mate, http://www.georgiawatersports.com/ http://www.nwvintagecycleparts.com/ SKU: 95821-10145-00 BOLT, FLANGE as for the square tank, there are loads in UK ebay!
  7. they are not stripped, they are turning the inside lower damper rod. you need to get a 15mm dowel and chamfer the end then ram it down the inside tube to lock the damper rod after taking out the spring. A grip in the vice to hold it and then try the allen again. it will be tight. next time you do this you need to "shock" the allen off or it will turn again!! drewps
  8. to theforum wtf61! try a little oetrol additive as I think the carbs are displaying a blocked pilot hole at the top front of the carb. this tends to hang the revs. it usually gets worse when hot!! have a look at the sticky at the top of this section as there are some usefull links for you to try. drewps
  9. drewpy posted a topic in The Bar
    some cool shit, only shows up in UV one for you Goff? http://www.slightlywarped.com/crapfactory/...ighttattoos.htm
  10. you can get the lower bolts from yam dealers still! you can also get pet cock rebuild kits off ebay
  11. drewpy posted a topic in The Bar
    Hi Peeps, just got back from 10 days in Austria with the scouts, white water rafting, mountain biking etc. in Stanzach, Lech Tal. bloody knackered now as it was a 26 hour coach journey. I'll catch up over the next few days drewps
  12. drewpy replied to mcmunzell's topic in The Bar
    just google, not sure who sells them in usa, but allens performance seels them in UK. I have seen some new xs650 34mm on ebay.com, should just need to re jet for the bike!! drewps
  13. I shoved a clear washer tube in the lower float bowl with the carbs off the bike and clamped level. easy to do and was 2mm from top of float bowl as per specs. drewps
  14. drewpy replied to mcmunzell's topic in The Bar
    white smoke = fuel, float too high or leaking for cafe look I liked the xs750 tank on the 400!! try new mikuni flat slides, they'll cost though
  15. obviously not been to eccles lately
  16. good luck foams and whtch for the left handed screwdrivers and buckets of steam
  17. you can get the dials refaced with larger digits.
  18. drewpy replied to mcmunzell's topic in Yamabyss
    I would suggest you keep the airbox, as these are the best for the bikes ( and rare) you could always try bolting on an aftermarket megaphone, then everyone will hear you!!
  19. drewpy replied to mcmunzell's topic in Yamabyss
    rewiring is a matter of patience, wiring diagram and not being colour blind. If you can get a yamaha original service book, they even show where the loom goes!!
  20. the engine casings are the same, but you will need barrels, pistons, head (inc valves), cam cover and bs34 mikuni carbs/manifolds/air trunking. all the rest will suffice!
  21. which pilot jets? fuel air or mixture?
  22. drewpy replied to mcmunzell's topic in Yamabyss
    have a play with your idle adjustment, its on top at the front of the carb. you need to enrichen the mixture as the revs are "hanging" being too weak a mix. Mikuni BS34 is the 400 carbs can't see why the indicator switch cant work, double check its got all the correct buttons on and you may need to rewire the multi plug. drewps
  23. just to offset candy bra, I give you a yamaha 1972 advert ">" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="873" height="525">
