Everything posted by drewpy
Bottom crankcase cover leak on XS400
Yep. arrow forward and torqued to 7lbs ft ( 10 nm) in cross pattern. mines never leaked there ( elswhere is a differnt story )
XS 400 Caféracer
some faves of mine and i posted a racer in the video section which was LOUD!!
manchester Toy run 7th November
yep thinking of going, weather better be good
- Its wildfoamys birthday
I was busy yesterday, buon compleanno Foams- xs500 dual front disc brake conversion
no, i said you can use the xs1100 master cyl! the brake lever is irrelevant as its just a replacable part and common to all yam bikes of the era. you need a left caliper and mount for the dual system, check the caliper pictures as some had a swinging caliper which is different from the floating caliper which I think you have!!- SR 125 Noise
what was the oil like when you changed it. this will give you an indication of wear. ie did the last owner change the stuff- chrome platers ?????????
let us know what you decide to do BH250. http://www.rschrome.co.uk/index.html this was the one I used http://www.classicsandchrome.co.uk/1.html- XS 250 Master cylinder size
Jordan you can use xs1100 master cyl and left caliper and mount or if you can't find the left side stuff, SR500 caliper mounts on the left side. I tried the T pipe route but couldn't find room on an xs400 so used dual banjo on master cylinder ( no, not deer hunter music ) drewps- Well done Valentino
- SR 125 Noise
if you've just bought the bike, get a manual and service everything (should do that anyway) check timing, cam chain tension and valves. that way you get to know the bike in your own time and not at the side of the road (especially in the middle of nowhere) and you have a bike you can trust. good luck drewps- SR125 running issues
moo do you have a fuel filter on the bike? did you check the pet cock and clean? how old is the battery, with electronic ignition you NEED good amps and volts anything under 12.5 is asking for trouble. check charging with multimeter and it should read 13 - 14 volts @ 3k rpm. a duff battery will give the symtoms you describe! drewps- Why raincoats should be yellow!
- anyone want to be a farmer???
Kin'ell doesn't suprise me- Yamaha XS400 Kart
cool, i was thinking of doing one for the scouts, but the nearest track is 3 sisters and I'm not sure how much use they would get out of that. its a great project and well done!! drewps- Exhaust option?
contact Motad, I'm no exhaust specialist- 1978 xs400 bobber
cool ride, i think the q you need to ask is "what is the width of the the swing arm mount" if it will fit your frame width, the rest you can make fit I'm sure! drewps- best game ever
- Did I get the right shop manual for my bike?
XS400SH model you can get an offical manual. 20w 40 over 5'C is listed for that model drewps- How not to clean a bike
- Golfers, what are they like
two golfers were on a putting green when a hearse drove by. one golfer took his cap off and bowed his head. The other golfer was amazed at this act of respect and told him so! "its the least i could do for the wife" he said- Exhaust option?
its on the headstock- Did I get the right shop manual for my bike?
on the frame - Its wildfoamys birthday
