drewpy
Everything posted by drewpy
  1. drewpy replied to wild foamy's post in a topic in The Bar
    kin' ell foams. WHYD?
  2. drewpy replied to cegan09's post in a topic in Classics
    I wouldn't recommend needle bearing for that application. the swing arm only has limited movement and the loading on it is really suited towrds phosphor bronze bushes!!
  3. more likely the caliper has seized, just strip it down and clean. i'd do the M/C while your at it!
  4. couple of things; I would say from the bottom of the contact cover, there is a little slit there from drainage. maybe a camshaft seal has gone ( easy fix) burinng oil with a leaky exhaust blowing back onto the head leaky head gasket getting oil blown up into the fins
  5. drewpy replied to barkwindjammer's post in a topic in General
    come on folks, only £55 to go!!
  6. I expected you to leap that little road deviation!! never mind, best bit was no other traffic around, lovely
  7. drewpy replied to cegan09's post in a topic in Classics
    ooh i had a z400 once, best leave it at that!!
  8. drewpy replied to Campbell45's post in a topic in Classics
    look at coker tires if you want bobber http://store.cokertire.com/popular-tire-applications/motorcycle.html
  9. drewpy posted a post in a topic in Yamabyss
    There is a factory in Northern Minnesota which makes the Tickle Me Elmo toys. The toy laughs when you tickle it under the arms. Well, Lena is hired at The Tickle Me Elmo factory and she reports for her first day promptly at 8:00 am. The next day at 8:45 am there is a knock at the Personnel Manager's door. The Foreman throws open the door and begins to rant about the new Employee. He complains that she is incredibly slow and the whole line is backing up, putting the entire production line behind schedule. The Personnel Manager decides he should see this for himself, so the 2 men march down to the factory floor. When they get there the line is so backed up that there are Tickle Me Elmo's all over the factory floor and they're really beginning to pile up. At the end of the line stands Lena surrounded by mountains of Tickle Me Elmo's. She has a roll of plush Red fabric and a huge bag of small marbles. The 2 men watch in amazement as she cuts a little piece of fabric, wraps it around two marbles and begins to carefully sew the little package between Elmo's legs. The Personnel Manager bursts into laughter. After several minutes of hysterics he pulls himself together and approaches Lena . 'I'm sorry,' he says to her, barely able to keep a straight face, 'but I think you misunderstood the instructions I gave you yesterday...' 'Your job is to give Elmo two test tickles
  10. drewpy replied to Campbell45's post in a topic in Classics
    this should give you the information you want! rim to tyre app chart
  11. drewpy replied to rollsroyce's post in a topic in The Bar
    good idea, i seen them at my local Aldi, had a wierd type of key that i could lose and never replace
  12. never really got into that show and all i've heard is its not worth the money! is that you on the kwacker OT? you look prettier than the last time i saw you
  13. drewpy replied to 1946415cd's post in a topic in Classics
    depends which part of the world you come from? no point in giving info for UK if you come from the states
  14. drewpy replied to cegan09's post in a topic in Classics
    some more rebuild tips use food bags with the white matt label background and keep things together and in logical order. photgraph everything ( especially inside the headlamp bowl) make note of wring runs and tube locations. have somewhere to keep finished parts ie the loft! don't throw anything away even if knackered, you may need to destroy something to get at a hidden bit! better to do that on a knackered part! make a list of things to do and cross off when finished don't set a budget or time limit
  15. drewpy replied to ayhaytch's post in a topic in Yamaha Workshop
    if you do a search on the forum, q's like this are already ansered! http://www.yamahaclub.com/forums/topic/13764-sr125-owners-manual-where-can-i-get-one/
  16. drewpy replied to bodean's post in a topic in Classics
    ebay is your friend http://cgi.ebay.co.uk/YAMAHA-XS400-XS-400-FUEL-TAP-REPAIR-KIT-206347_W0QQitemZ400057646583QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item5d254b3df7 the calipers will need stripping ie take out the brake piston and check for rust. you can get stainless pistons from germany 20euros or get someone to make a set! also sounds like the carbs need a strip and ultrasonic clean with new needles etc
  17. drewpy posted a post in a topic in Yamabyss
    http://games.adultswim.com/robot-unicorn-attack-twitchy-online-game.html
  18. drewpy posted a post in a topic in Video Section
    No wonder he can't get a partner acting that that!! <object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  19. drewpy posted a post in a topic in Video Section
    "he managed to mask his contempt, it was touch and go though" brilliant! <object width="560" height="340"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
  20. drewpy posted a post in a topic in Video Section
    cracking little film <object width="560" height="340"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
  21. drewpy posted a post in a topic in Video Section
    Foamy, OG, OT, BWJ, Goff and Merv filmed in technoblue!! <object width="560" height="340"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
  22. stick with it <object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  23. drewpy posted a post in a topic in Video Section
    Vagina dentata, when you don't need a penis any more!! <object width="560" height="340"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
  24. drewpy replied to bodean's post in a topic in Classics
    tick over does mean the bike is running at idle! 8000 miles on a set of contacts may need renewing!
