drewpy
Everything posted by drewpy
  1. drewpy posted a topic in Video Section
    hop to it! <object width="445" height="364"><param name="movie" value="http://www.youtube.com/watch?v=zQy4jfFSYeo&hl=en_US&fs=1&color1=0xcc2550&color2=0xe87a9f&border=1"></param><param'>http://www.youtube.com/watch?v=zQy4jfFSYeo&hl=en_US&fs=1&color1=0xcc2550&color2=0xe87a9f&border=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=zQy4jfFSYeo&hl=en_US&fs=1&color1=0xcc2550&color2=0xe87a9f&border=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="445" height="364"></embed></object>
  2. changed my mind on the headlamps coz i saw a davida helmet ad with a triumph and it looked the business. so i've cut some ally sheet and formed a couple of holes for haleogens to fit behind. hopefully Vez can help me with some bracket and a way of mounting the lamps to the board here's some piccies
  3. the part number is 90890-01111 which when googled is the same as rd400/250 C and E
  4. you have to use battery, needed for charging and running lights and ignition
  5. why don't you have a ceiling cat?
  6. drewpy replied to Lorain's topic in The Bar
    to the club lorain, sometimes go to devils bridge for a ride out, so keep an eye on the rideout section!!
  7. drewpy replied to casper954's topic in The Bar
    very nice, bet your chuffed with that!!
  8. apparantly he didn't know there was a car there!!!!
  9. there was a spread on them in the Classic bike mechanics last month, i think i used them a couple of times!
  10. drewpy replied to vav303's topic in The Bar
    vav303, sounds like you have a weak fuel mix in the pilot circuit in the carbs
  11. drewpy replied to Goff's topic in The Bar
    back goff. still have the usual daft posters and foams comes and goes like a cuckoo clock. og is still incontinent ( or was that Merv and his crabs) good luck on your nuptuals and I'm sure you'll be ok with the exam results!
  12. 2a2 models got disks all round. the se's had drum rear which got the "expanding rear brake" which was via rod. the resevoir indicates you have a hydraulic system and a disk rear brake i've used none of those tools, and got by with a puller for the stator, and putting the bike in gear to hold clutch ( with a rag between teeth) I'm sure the job would go easier if you had those tools
  13. maybe it just needs its annual oiling!
  14. drewpy replied to Dav M's topic in The Bar
    Davm good choice of bike mate. did you get it on 0%?
  15. drewpy replied to ashr1's topic in The Bar
    ash ooo arr!
  16. strip carb and clean and check ignition timing, new plug should cure it. put a fuel filter inline from the tank to the carb
  17. sounds like a brake shoe system.
  18. local brass band marches past OG's house and he can't resist a play on his trumpet <object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  19. <object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  20. <object width="560" height="340"><param name="movie" value="http://www.youtube.com/watch?v=3sYVLHwf7JQ&hl=en_US&fs=1&color1=0xe1600f&color2=0xfebd01"></param><param'>http://www.youtube.com/watch?v=3sYVLHwf7JQ&hl=en_US&fs=1&color1=0xe1600f&color2=0xfebd01"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=3sYVLHwf7JQ&hl=en_US&fs=1&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
  21. <object width="560" height="340"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
  22. drewpy posted a topic in The Bar
    It's pretty realistic. Just wait for it to load, then use arrow keys to control the car.
  23. We've had the Oscars and the Baftas, now "the bongo movie biz celebrates the lives of those they lost this past year," <object width="560" height="340"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
  24. drewpy posted a topic in The Bar
    Tit Monday; soon to be this time of the year and in the name of science and pervertary voyerism there is now a web site dedicated to this arcane art!
  25. build looks good, keep it up!!
