drewpy
Everything posted by drewpy
  1. <object width="400" height="300"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=8461831&amp;server=vimeo.com&amp;show_title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp;fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=8461831&amp;server=vimeo.com&amp;show_title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="300"></embed></object><p><a href="http://vimeo.com/8461831">Skateboardanimation</a> from <a href="http://vimeo.com/singer">Tilles Singer</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
  2. NC Motad make 'em but you will need to import from Uk ebay also try ebay germany as its a popular bike there. don't forget there is a dohc model which is completly different.
  3. lookin' good POD
  4. <object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  5. <object width="480" height="270"><param name="movie" value="http://www.dailymotion.com/swf/video/xcv6dv_pixels-by-patrick-jean_creation"></param><param'>http://www.dailymotion.com/swf/video/xcv6dv_pixels-by-patrick-jean_creation"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed type="application/x-shockwave-flash" src="http://www.dailymotion.com/swf/video/xcv6dv_pixels-by-patrick-jean_creation" width="480" height="270" allowfullscreen="true" allowscriptaccess="always"></embed></object><br /><b><a href="http://www.dailymotion.com/video/xcv6dv_pixels-by-patrick-jean_creation">PIXELS by PATRICK JEAN.</a></b><br /><i>Uploaded by <a href="http://www.dailymotion.com/onemoreprod">onemoreprod</a>. - <a href="http://www.dailymotion.com/gb/channel/creation">Arts and animation videos.</a></i>
  6. getting all too common, no-body indicates anymore
  7. drewpy replied to mike1949's topic in The Bar
  8. there is, its just that they have a plug over them and that needs to be extracted. are you sure it isn't oil burning?
  9. wasssaaap dave of old'em to the YOC what's the craic with this shitty rain this mornin?
  10. if the right hand side isn't firing, it will be wet and oily. can you confirm it is firing?
  11. the special fork stantions are longer (and the springs) this will make the bike higher at the front. I have a set-up on my tracker, but deliberatly did this along with rear shocks to raise the overall height of the bike. they are all 33mm up to the dohc models.
  12. drewpy replied to 2 Wheels's topic in The Bar
    Ha ha, good one. sounds like a bmw driver to me
  13. <object width="640" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
  14. The hero of an old run and jump arcade game rescues the princess. He doesn't realise his troubles have only just begun. <object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  15. drewpy posted a topic in The Bar
    Exclusive! One of Britain's most famous faces hoovering up a fat line of coke:
  16. drewpy replied to drewpy's topic in Video Section
    remix for OG after a few pints <object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  17. drewpy replied to drewpy's topic in Video Section
    here's the sing along version with words <object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  18. drewpy posted a topic in Video Section
    what happens when BWJ goes to bed and hangs up his mouth? click to find out <object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  19. and whatch those bleedin' pot holes from winter!! glad your out and enjoying it! nothing comes close to the feeling!
  20. no, I'm out all day
  21. did you mix up the rings and pistons to bores? if you used the same componets together, i would say the valve guide seals are not sealing!!
  22. yes, but to check; feel the exhaust and they should both be the same (hot) temperature
  23. wow that was brill
