Everything posted by drewpy
xs400/sr250 front end
not sure on the yolk sizing, but you would need the wheel/spindle as well as it runs a 19" size wheel and the brake caliper is on the opp side! look forward to seeing you creation take shape on another thread!
Clutch Problem
they all do that sir!. its the oil circulating that rotates the clutch basket, and the plates that do move induce the rotation.
Happy birthday merv
it goes! at last
good to hear your doing ok with the bike. It can be fustrating sometimes, but that is part of its charm great when it all works and you have done it yourself
diamonds in my Poo
after BWJ's trip to south Africa, he has a dilema...... <object width="640" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Motorcycle Transportaion
get breakdown insurance and "break down" there, get a tow home. obviously it needs not to run!!
Weird Electrical Issue XS500
on my 400 it is
is anyone else as bad?
what do you call a french man with open toed sandles?............ Philipe flop
xs400 clutch adjustment
cable too tight, need to slacken off the cable cable too tight, need to slacken off the cable eh!! after reading that a doz times, haynes does sound right, in its "implication" lever adjustment is the fine tuning bit!
Just purchased a 1980 XS 400 special
yes, the clutch will slip, use semi synth if your keen not always, some carb stuff, some brakes and switches may be compatible also can be said re SR range braided brake lines, modern pad material and R1 engine (last one was not serious)
- rdlc fork springs
- rdlc fork springs
full right position is for parking on an unlit road acording to UK law! as for the rest, check the earth strap and connections to the starter solinoid and check fuses
XS 400 Adjusting mixture
the yellow is the pilot/ idle mixture adjustment the exploded spring and screw to the left is the carb balance adjustment (it only adjusts one carb to match the others flow rate!) hope that's clearer
happybirthday drewpy
hic!! show mw the way to go homwe i'm tired an' i want to go to beaaaaaaad
Very lucky!!!!!
Jeez, the fast and the furious vs raleigh bike the window cleaner
cheers Guys, just had a kebab to celebrate, now where did i put those slippers and pipe.......!!
they are the same thing throttle stop screw, just lifts both the revs via the butterfly's in the carb correct it balances the butterfly's in side the carb so the engine draws the same air/fuel mixture in both cylinders that is the pilot/idle mixture screw that refers to the pilot/idle mixture screw
XS400 Petcock Help
recheck the seals are sealing, i think i had to do mine as i got the parts wrong way!
wanted mint yamaha chappy 80cc
this should be in the wanted section. so I'm closing it
I need help! i cant find any info on this bike
no
- Key Codes, anyone?
XS400 Petcock Help
no, it should only pass petrol in the prime position
Delete Topic ?
put the solution in there and PM me and I'll close it. this might help future peeps if they have the same question drewps
The garage
nice bikes, bet their fun to ride
