drewpy
Everything posted by drewpy
  1. to the forum Ben if you are in the UK, try custom fasteners have a look at my build on my tracker
  2. drewpy replied to steve_w's topic in The Bar
    congrats, off to Rivi?
  3. drewpy replied to pepperami's topic in Classics
    aye, but when they run they're great. have fun pepps
  4. that was fantastic, brought a tear to me eye
  5. happened to mine, twice!! grind a nail down real fine then tap them through the top with a pin hammer. this will push them through the hole, the hole will be bigger, but my carbs still run ok! drewps
  6. drewpy replied to frankj's topic in The Bar
    motoward granby's yamahatopdog cmnsl bike bandit
  7. Just this min seen the local news and a certain ms Goff (aka Lisa Bucley)was on there, summat to do with salford uni and a prosthetic leg for a foreign chap. if i find more i'll post found some http://menmedia.co.uk/news/s/1241008_student_brings_teen_10000_miles_for_new_leg
  8. drewpy replied to akronevan2's topic in Classics
    I thought that all the xs range used allen heads!! anyways I always use an impact driver when undoing ANY cheese head screws
  9. drewpy replied to friedegg's topic in The Bar
    take it easy and don't panic and you'll be fine good luck
  10. drewpy replied to pepperami's topic in The Bar
    I just notified them of the new CC and the engine number. did it when on SORN. its the frame that carries the reg number and that's the important one drewps
  11. drewpy replied to Jryan88's topic in Classics
    how can the starter motor be filled with oil?, there is a water drain hole on the bottom left side, but i can't see any other way for oil to get in there! If your on the side stand and remove the 4 allen bolt stator cover, oil does come out. the bike needs to be on its main stand to remove the cover and left case. oil pools there via the crank bearing don't forget the starter clutch, which wears flats. you can get new kits from mikes SX
  12. drewpy replied to Ttaskmaster's topic in The Bar
    way hay!! congrats to you both hope Claire likes bikes as much as you?
  13. apply voltage and you should hear a click as the bus bar go across the terminals inside the unit. try and get a code off it as relays are really common and cheap.
  14. 14v @ 3k revs is within spec. with these bikes, you need a good battery, if it's not holding charge then you wan't get back a decent charge!! the tesing of the solid state voltage regulators only states the above test (14v - 14.7v) with a fully charged battery. rectifiers are diodes which only allow electricity to flow in one direction. this process converts AC current to DC, that is why you won't get a reading one way. I'd check battery condition firstly NEVER RUN ENGINE WITH BATTERY DISCONNECTED! drewps BTW I just posted a link for a parts book for the SJ under xs400 links
  15. only company i know of PSW customs
  16. when you get the bike going, run a volt meter on the Batt terminals. you should be getting 13 - 14.5 volts at 3k revs. if not i suspect the voltage regulator first drewps
  17. drewpy replied to martiniman's topic in Yamaha Customs
    There seems to be a problem with these. this dragstar has a couple of rattles on the front end
  18. to the forum loopy i was busy with me tracker and polishing me other bike for tomoz ride
  19. drewpy posted a topic in The Bar
  20. drewpy posted a topic in The Bar
    Clever bit of coding - it's all perfectly safe for work, until you select all of the text and colour is automatically applied to each letter. http://fichtre.net/yop.html
  21. I'd tend to lean towards clutch drag. make sure its adjusted at the engine side first. there is another thread about this which, quite frankly, has been done to death
  22. got them from HEL
  23. that GL750 was a rare one, built to offset kwacker KH and the suzie GT triples! thanks for posting
