Everything posted by drewpy
Getting painting done.
I'd look at their work first. I had clear coat on a new tank, all side panels, seat strip and rear cowl all with transfers ( i supplied) for £200 4-5 years ago. still looks great and worth the dosh drewps
Insurance, pay in lieu
bloody minefield mate! cover your arse and get professional advice drewps
I want one of these please
that's the soup dragon burning his mullagatawny did you see the story about olibre postgate, he scripted the clangers and even had swear words in them. no wonder i grew up the way i did
old urls not working
your just missing Goff I agree most of our "characters" have gone their ways, we need new blood as its turning into a yamaha workshop forum!!(although there's nowt wrong with this per se)
erm.. "You have no idea how scary it is to know how many people on here are buying some without knowing how powerful these really are. By the time you blink your eye you're already blind, and just the light going though the skin covering your eye is probably enough to blind you." suppose you could point it at the moon or something
Is this Gadget cool or what! not bad price and I'm sure I'tt get lower this time next year http://www.saverstore.com/product/20048312/Aiptek-MobileCinema-D25-Portable-LED-Projector-with-Integrated-DVD-Player pity the replacmen lamps are more expensive than the whole unit
o2 sensor plugs
have a looksy here for connectors http://www.autoelectricsupplies.co.uk/about.php or here http://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php
What size tires can I fit on an 82 XS400SJ?
i'll re post the tire to rim app chart http://www.dropbears.com/u/utilities/tyrerim.htm
Need float needles (or assemblys) for XS360 1U4
they are listed on CMSNL 49 Euros took 30 seconds to find
cleaning carb for first time
don't force anything don't poke anything clean outside first peeps have boiled in lemonjuce/water combo and it came out good (google it) I recommend ultrasonic cleaning, saved a lot of hassle my last carb was vapour blasted and looks the business get a rebuild kit with all the jets first and check sizes against the manual use compressed air to clean through and also carb cleaner's got its use there drewps
BEST ROADS TO RIDE
i'll second that been twice now to Ni and the place is amazing
- NEWBIE FROM SCOTLAND
Perth Motorsport 2010
Aye greet weather we're having today. just come back from Barnsley having met up with Vez
Finally back with a Yamaha
Mike it'll be like the song "things can only get better"
Posting in wanted section
its a primarily british site (via australia) so its in £'s there's plenty of friends across the pond as members drewps
Stuck Rear Brake Piston
i've used a variable grip and turned the piston around whilst pulling, evetually it come out
The XS500 gets a rebuild
looking good Cegan09
Yamaha Maxim XS 400 1984
there was 2 power versions of the dohc engine a 38 and a 45 bhp might explain the different code or its just a casting stamp (series 2?)
noah, its in the xs400 link sticky now drewps
Still having hard start issues
after 5k miles, i'd replace the plugs
you butcher try speed sport (yamahatopdog)
could be ignition, starter fluid raiseing the octane rating to at least get a fire!! try checking your earthing, undo the straps and clean the area (the starter slowly moving indicates this!) check igntion timing check battery for amps or try a tempory car battery drewps
XS 500 CRANKCASE SPLITTING HELP
I use a rubber mallet. just make absolutly sure all the screws are out
1982 Yamaha Seca 400 turn signal installation
usually there's only live feed (brown) and the indicator body has a ground wire (black)
carb help
tenners comming out of the exhaust!
