Everything posted by drewpy
Traffic Effin here,,,,,Traffic Effin there
- Traffic Effin here,,,,,Traffic Effin there
I'm assuming its an enfield- 1976 xs360 carb intake boots
they will fit as this has been mentioned before in this forum changed me sig again- How was your cruise?
that was like squires to me on saturday nite- DT Anorack"s
anyone seen "on any sunday"? steve mcqeer, dirt riding, flat trackers. cracking film. just do a torrent search!- Hey hey hey!!!
that was some hairy riding- 1976 xs360 carb intake boots
BTW xs400 boots will fot the 360 as theya re the same size carbs- Up Yours in his yoof
I used to like "bellie's going to get ya!" advert <object width="640" height="385"><param name="movie" value="http://www.youtube.com/watch?v=yN_R0J8kU5I?fs=1&hl=en_US"></param><param'>http://www.youtube.com/watch?v=yN_R0J8kU5I?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=yN_R0J8kU5I?fs=1&hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>- 2-Stroke meet - Squires cafe
its starting to annoy me too- Got a Sat-Nav ?
it use to be like that, called letterboxing!- Spoke wheel front of XS400
have deep pockets, is the '82 a dohc?- Ryans Ryde
sounds great and its a good buzz riding in a large group- 1976 xs360 carb intake boots
yep, that "place" is called a shop.- Up Yours in his yoof
seen that before, weird or wat!- 2-Stroke meet - Squires cafe
that was my exact thoughts when most of you rammed past me. lemmings also sprung to mind- Got a Sat-Nav ?
you can use your iphone or smart phone as well as garmin devices- xs 400 bobber
very nice is that a PSW hardtail? more pikkies please- Got a new (to me) 1980 xs400 Special
you have a choice; leave alone and hope that any rubber o ring is ok (if that's the model carb you have) Or remove the plug and have a look while the carb is out. personally I'd remove it and check the contents. I think if you drill a small hole and get a self tapper in there, you should be able to pull the thing out! drewps- Which engine oil and 2 stroke oil for 1993 DT50 ?
yea! I wouldn't ask cynic, he don't use any- Got a Sat-Nav ?
been geo-caching for years moniker? why "drewpy" of course got a geocoin that's going round the world. its been to brownsea island then saudi now its over in spain. there's even a cache in Antartica. It takes you to places off the beaten track and normally gives you a bit of history of the area. good heads up BWJ- xs400 flat tracker project
Managed to fit one of the micro switches inplace of the clamp screw on the lever bracket looks quite smart just got to find a small rubber to fit over the switch ( I might ask Kev!, so Paul said!)- Got a new (to me) 1980 xs400 Special
I think I left mine off and I use an inline filter I would use the new one with the new counterpart, mixing old with new is not good . sounds right, i have something similar with a looped clear plastic and it uses a small ball bearing Is the black plastic thing the diaphram? I put ACF50 on the diaphram to stop it cracking and keep the main jet piston clean. (slide!!) drewps some links http://www.obairlann.net/reaper/motorcycle/manometer.html http://www.therevcounter.com/uk-motorbike-forum/15892-diy-twin-carb-tb-balancer.html- xs 400 bobber
I've already done that for Kev, he just told me to feck orf even did him a pretty picture!!- xs 400 bobber
use photobucket. upload pikkies there. in photobucket, copy the IMG tags under the pickkie you wanty to post (clue it start with copy it where you normally write. you can still write either side of the IMG tags as normal simplz - Traffic Effin here,,,,,Traffic Effin there
