Everything posted by drewpy
- Newbie
- test..test
XS400 Fork Oil seals.. anyone ever successfully removed these without pulling your hair out
a little screwdriver you use to wire electrical plugs. Its small enough to get into the groove and flick it out
Up Yours in his yoof
kev, a bit below the belt, that
test..test
sorted it kev, mustn't have copied all the code. My son loves that series "ultimate warrior"
- yb100 4th gear prob
what you should have done is; loosen the lower allen bolt under the bottom fork. or it'll just turn the damper with the forks still in the bike and the wheel on, flick off the plastic cap and press the metal plug down (may need to use kinetic energy to start it(a mallet) as they corrode there. with the cap pressed down against the fork spring (its hard) get the missus to use a terminal driver to dislodge the clip ( it'll ping off so do it in a garage) CAUTION; be careful as the cap may jam and then suddenly let go the first one i did, i had to give to an engineers who turned out the cap on a lathe as it was that corroded in! if you can understand how I did the above, maybe you can work out a way of getting that cap moving with damaging the damper rod! maybe re-fitting temporaily back into the lower fork?
Front Brake Master Cylinder Ass.
the mm should be cast on the body 12mm methinks
- dt125
you need my wife to do that. she's a dab hand as I've rebuilt 3 different xs forks! question, how did you take off the seals with the stantions in place? you said you had stripped the forks
New Member
Aaron thought it was OG masquerading again as that's his rdaircooled moniker
2-Stroke meet - Squires cafe
bit more VId some stars in the making?
just quick question for 81' xs400 special ll
....or dribble
sneaky I'd say, not offering any out..mind you OG's dentures were playing up again that weekend and it would'nt have been a pretty sight if they fell out
Fuel to oil ratio help
CBD, I thought you use avgas especially with a 15:1 compression ratio enjoy your ride out, seems the weathers going to be good! I was on a downer, till early this evening when Mike phoned me to say that he has 2 free tickets for the BSB this weekend that's pit passes and hospitality for 3 days, but only going sunday as work and scouts saturday! weekend sorted
the spring is stepped so its dead easy to remove!! remove that and get a piece of rag or flat wood to stop the alloy on the bottom leg from being damaged. use a pry bar under the lip of the seal and push the other end down to lever out. sometimes i've had to pick out the seal in bits and use heat to soften the rubber and tease it out!
Spoke wheel front of XS400
i was talking spoke wheels with disks. the E models (economy) had drum front and rear
dribble
New classic yamaha owner
007 get all the fasteners soaked in penetrating fluid, before you start on the bike. Get an impact driver so you don't chew up those head screws. could be looking at a rebore at the very least drewps
new member looking to pick the grey matter :)
£150 sounds a good deal to me!
the only direct replacement wires for the xs is the xs250 UK models. the rd's and xs650's have a bigger spindle, but if you got the money and the inclination do it! BTW you are talking £1000 here in machining costs and buying the wheels. my xs250 ones with new spokes and rims were £800 also you have a 16" rear wheel, so bear that in mind if replacing rims
I remembered the FJ there as well. Man, you should have said hello and we would have treated you like one of the boys. ( gotten the piss taken out of you ) 'nother vid from the 350b guy
YEEEHAWWWWW!!!
wooooo well done goffski all that hard work has finally paid off.
DT Anorack"s
link don't work, that stopped your whistling Vez
Electric motor windings
well you know what they say? one good turn deserves another....and another.... (ad finitum)
