Everything posted by drewpy
- being a dickhead's cool
- girl dancing
Monstrous discrepancies
- Tooth story
very funny and a good little read http://hyperboleandahalf.blogspot.com/2010/09/party.html- Boyz N the Ring
Yo Mofos chek out da vid maaann, t'is wikeed- GT80b???
try some bearing retainer. bit like threadlock- XS250 Carbs
looks like the floatey bits will fit as they share the same 4 digit number ( just the model # is different) OTHERWISE THE CARBS ARE A LOT DIFFERENT- brakes jerking
could be oil on the disk!! check fluid levels and brake pad wear to be sure- Just wanted to say Hello!
- Silly idea
NW200 better than the TT I think and some cracking roads/ giants causeway etc- A bit of advice sort after...
on the schematic, one of the white wires eminates from the middle of the stator, that one is not used. black is the negative part of the voltage reg, green the output to the feild coil and brown supply to the voltage regulator.- xs400 flat tracker project
bloody 'ell, I'll have Kev wanting it!- Foamy would look cool on this
georgous, and in my fave colour scheme.- Hi from a newbie
- New 87 FZ 600 Owner from Canada
white ones are the outputs to the rectifier (stator) and the 2 wires are the regulated 12v input to field coil via the voltage regulator.- xs400 flat tracker project
I thought of Satin black all over, but its been done to death- Road Wizards 1 day event Greenfield
looks good vez, busy sunday I'm afraid though- Silly idea
lets just go to the NW 200 and enjoy the criac! then we get get pissed and not worry aboot drink driving!- what and where'
its NI so part of the uk- xs400 flat tracker project
nowt wrong with me photoshopping skills, just no point in spending hours on a mock up- CHRISTOFFESER!!!
why don't you PM each other (its like email, but using the forum facillities)- xs400 flat tracker project
yea, like the tracker bit on top, food for thought- Got a new (to me) 1980 xs400 Special
do a compression check first to see if you have out of balance cylinders. check valve gaps and ignition timing next, to manually adjust the carbs, place a 2 x 2mm bits (with the carbs off) under each butterfly valve and slowly pull the throttle up. the idea is to get the bits to drop at the same height as the butterflies begin to open.- new member..ish:)
- Tooth story
