drewpy
Everything posted by drewpy
  1. about 2 miles then
  2. keep taking the rat poison Dave
  3. did they actually go anywhere? mostly standing around and posing for pictures
  4. drewpy replied to a post in a topic in The Bar
    found this for you Dave, great for winter hacking...
  5. this is a real invoice form a fellow poster on the chopper underground. it was a heart attack, luckily he had insurance and only had to pay the smaller amount!
  6. drewpy replied to drewpy's topic in The Bar
    you won't make it back mate!
  7. scary stuff http://www.youtube.com/watch?v=DnyT7PHSvxE&feature=player_embedded
  8. drewpy replied to a post in a topic in The Bar
    better than being ignored OT
  9. why are you showing video of a car and a different bike? your totally throwing me off just undo the freeking points cover, take off the contacts plate, undo the 10mm bolt on the end of the camshaft. lube up the pivots and check for rubbing. replace and retime/set the points.
  10. found your problem, it was under your tank
  11. looks american Pat as befits the sissy bar on the back of the bike
  12. drewpy replied to paddy99's topic in Classics
    yea no problem, no idea who you are? but have a bike!!
  13. are you sure you have an xs400 manual? no needle bearings in the top end, the cam runs directly in the head! no govenor rod (whatever that is) don't forget this is a sohc model not the later dohc the advance mech is the second picture! is that the actual picture of your bike?
  14. its on the bike mate, not in a book ignition, its behind that finned cover top of engine, you only need the haynes to do the timming!
  15. he might 'av said "yea, for a fiver" if you did
  16. drewpy replied to a post in a topic in The Bar
    we should do our own scary vid we have enough monsters on here
  17. try locating the noise with a screwdriver touching the engine and the handle in the ear. doesn't sound good, like a dry bearing! is the oil light lit then goes out when started? have you got enough oil in the engine? measured when the dipstick is resting on top of the threads!! could also be the end camshaft advance mechanism, might just need to strip and oil!
  18. KN nice the xs750's , thoses carbs look like they'll need stripping and cleaning
  19. and never, NEVER, throw anything away even if it looks irreparable you might need it for comparison sakes
  20. drewpy replied to drewpy's topic in The Bar
    sorry Pat
  21. drewpy posted a topic in The Bar
    some weird happenings
  22. you'll be ok to take out the kick shaft, it should just pull out when you have the cover off!, why not put an oil temp gauge in there using a 45' elbow?
  23. I know, but CBA finding it
  24. the clutch is disengaged somehow
