Everything posted by drewpy
		Bleeding the front brakes
		try clearing the tiny hole within the master cylinder its a return orifice for the brake fluid
		halfway there XJ900
		stunning looking bike, clicky pikkie to sitey
		Foamy's New Toy, XJ650 Turbo :)
		used that stuff on me tracker tank, stinks a bit (still does) but sorted!
		stopping sunglasses getting scratched.
		Hairy specs!
		N West Rally   Blackpool
		have fun John and ride safe. There was always a lots of scots in Blackpool, especialy when it was their holiday weeks. lets see you on the big one
		Getting to know my bike..
		I've looked at the chain link too and just go for heavy duty standard chain and keep it oiled. for £22 I'm not going to bother with anythiing else!
		why are you posting this in the bar? workshop would be more appropriate and did you do a search on bleeding brakes? we have another member having the same issues (abet a different bike) but its all relevant!
		Need help with neutral light
		did you earth out the light blue wire near the neutral switch? if the lamp didn't light its either a live supply problem or, as said, the bulb has gone and needs replacing!
		new rider - 83 maxim xs400 help
		short intro would be nice as a first post
		I'd start collecting parts for the bike when your on your travels. I personally wouldn't try and start the bike until at least I had the head off to check for rust. With the added ingredient of the turbo! those need a lot of tlc in my opinion and it might be worth checking the bearings (and pricing up for a refurb) good find though foams, the yam version of Top Gun
		sr250 help
		sounds like it needs a tune up! and maybe a new battery
		XS250 Front fork springs (dimensions)
		Andy, when buying for your 250, the 360 and 400 models are identical frame wise but make sure they are SE as that model has a slightly longer stantion. You may also want to check out Wurth springs based in germany! (via ebay) drewps
		New England Regional Chili Cookoff
		sounds like hot stuff Mmmm
		scratch 'em and buy a new set, i'm due new for this year!
		XS 250 Clutch Cable How to Replace?
		as merv said, but you need to remove the final drive cover to unhook the cable. The black "plug" needs jemmying out with a flat bladed scewdriver. Gives you a chance to clean all the crud, check the front sprocket and the charging wires for damage! make sure the cable has the easiest path to ensure its smooth operation. I just fitted a new one last week and it was so light in operation as opposed to the old one.
		warming up for weekend, John, why not stay overnight? there's a free day out on the 8th at Northwich thundersprint. danny webb, Jim Redman,Cal Crutchlow etc etc will be there. Its about an hour and half from Blackpool! http://www.thundersprint.com/latest_news.html
		black and white battery
		just perusing t'internet and came across these peeps http://www.blackandwhitebikes.co.uk/lightweight-motorcycle-battery if there is enough interest i recon I could get a 10% discount for YOC members!
		XJ650 Turbo, any good?
		don't lose interest with this bike will you Foams? should be a good build and if you have a spare turbo, I'll take one for my xs
 - Hello
 - New to YOC
 - Hello
		New member from Slovenia
		to the YOC
 - 1992 xj600
 - new member
 - New Guy
