Everything posted by drewpy
Yamaha xs250
now i'm confused, you said there was no spark in your first post. so you now got a spark now and there is another problem? is there anything thing else we should know?
XS 250 Ignition issues?
ebay, make sure they are for either contacts or electronic ignition!
Yamaha xs250
Rf (right fire) Lf (guess) no flywheels on the xs, you just remove the left cover (4 allen bolts) on the centre stand and the oil won't come out! tip; if you over fill the oil, you can get rid of excess via the side stand method!
XS400 not charging.
not sure where you are from but electrex world do a combined unit
Lowering (79 XS750)
try rk leighton covered my xs seat for £20 with leather supplied.
new group, familiar name
Ladies and gents I give you.... Spinal Pat
- ponycorn game
The Regular Birthday slot
congrats on another year Merv
- Exorcist advert
BP7-ES is the one listed
Yamaha xs250
If you look at the wiring diagram, the pints earth the coils which have a red/white positive feed via the ignition switch. ther is also a condesor to prevent sparks across the points, preventing arcing (sparks) which will erode the contact surface. the time the contacts are closed it powers up the coils in primary coil and when the contacts separate, the built up power in the coils has no where to go so passes to the secondary coils and jumps the spark plug gap (the easiest earth path). thats why HT leads are well insulated, stopping any earth leakage. hope that sinmplified explanation helps.
XS400 not charging.
the regulator may not work for that type of charging system. It could be for a permenant magnet one! have a ganders at your earth connectins too
The NW 200 2011
glad I couldn't make it in the end. Better be back to normal next year!
81 Special 400 won't run above idle, need carb help
try the float bowl too, there is a passage way there too!
Update on wife's pregnancy!
nice one, looks like she's riding an xs
- morphsuits
Yamaha xs250
get a battery! check fuses by removing and cleaning the glass fuses. no power as such across the points its a ground for the coils.
- 1978 xs 400
XS 250 Running issues?
have you put the O rings back the correct way? mikexs describes the way they go in in the advert for bs34 carbs
signal issues with 83' maxim 400
I would dsay its an earthing issue, check all black wires from the signals and clean frame around them.
presumably its an xs400! the carbs need a really good clean, ie strip and all the orifcies clear, use berrymans or seafoam and blow through with air.
- smoke over yorkshire
Foamy's New Toy, XJ650 Turbo :)
wait till you see the rest of the bike.... anyway
in weakens the mix! the slow to return to idle usually means its weak. If when it is warm, what is the response like then?
cheers fellas
