drewpy
Everything posted by drewpy
  1. drewpy replied to stealth94's topic in Naked
    As it happens, I just got an official Yam service manual for the fz600 (in anticipation, thanks Brownie). A 1986 edition no less. stock fork length is 517.5mm or 20.4". min free length 512.5 (19") the engine is an XJ600 and gas flowing and Neta exhaust seems to be the favoured route with a stage 3 dynojet!
  2. deja vue methinks
  3. drewpy replied to tiko's topic in Projects
    That's shame mate, you were doing really well too!
  4. kaizer lots of drag artistes on here too
  5. Elffie good buy there, give it a service and probably have to strip the carbs as full of gunge (modern ethanol fuel to blame)
  6. found the cheapest sheet baffle packs from kart shops. there's ZIP kart near me.
  7. drewpy posted a topic in The Bar
    Just put the engine in the Aprilia SR50 and the engines runs! that's a relief, not the same when it is someone else's motor. bought a cheap barrel and piston kit from Poland via eBay and had to modify/chamfer the ports a bit and got a spannie off gumtree for a 125 and got that to fit with a bit of welding. Carb spews out fuel on over flow, so need to check that and just need to dial in the jetting. hopefully the Mallossi variator mod will work as advertised! need to strip the front caliper and paint it and bleed brakes new fork oil etc and should be good to go!
  8. its sick from the night before
  9. its ok to pack the baffles with glass, its what normally happens anyway. Just check for any performance deterioration as you may run a bit rich.
  10. no fucking way... check this out <iframe width="560" height="315" src="http://www.youtube.com/embed/4Am7oKBD3PU" frameborder="0" allowfullscreen></iframe>
  11. so George white has gone bump, they had a new shop in Bolton and wondered why it only lasted a month! I think they spent too much on supporting the BSB
  12. drewpy replied to up.yours's topic in Random
    I was trying to get the pun, but there isn't one is there? copy off the document (crtl + c) and paste it into the forum text box (crtl + v)
  13. happens all the time, a few scoops and they turn out a munter. check these out though and you don't even have to drink! <iframe width="560" height="315" src="http://www.youtube.com/embed/wM6lGNhPujE" frameborder="0" allowfullscreen></iframe>
  14. just read "down to a sunless sea" by David Graham which has a 747 pilot as main character. written in '79 but Its a great read.
  15. that's better, true Blue ecu's are hard to diagnose, but something is not right as the first one blew, there is a electrical spike frying the bugger. clutching at straws, I'd look at the voltage regulator before buying another ecu.
  16. too Manchester United now, an affront to my senses
  17. that's a 10/4 flyday (or whatever you pilots say)
  18. gave us all a laugh anyway!
  19. ???, how am I supposed to read white letters on a white background? kin'ell!
  20. greetings OD, where ya from?
  21. never made that connection screw, nice one
  22. cool vid, took 8months to make as part of a degree course <iframe width="560" height="315" src="http://www.youtube.com/embed/iKqpvriKZuA" frameborder="0" allowfullscreen></iframe>
