Everything posted by drewpy
yzf750 engine out
what are carb clips? do you mean the inlet manifolds which have clamps on them?
Chinese carb
i used one in a gilera and it had replaceable jets (some don't) managed to dial it in and ran well. A few years ago so no idea regarding the seller
Moved to new server
seems to be a lot faster now 👍
1973 RT3 360 Restoration
usually for yams, its a whittled wooden dowel bashed down to lock inside the fork at its lowest point. Do a google search. also upturned bolt (don't know which size) welded to a rod. A quick spin on a drill could turned the bolt before the inner rod span.
XJ600 restoration project
great news, there's a sense of satisfaction in getting something going
hi im mick barr thanks for allowing me to post
YBR 125 Valve Springs please help
i agree then you can eliminate that. Double check valve timing too, been there done that
Anyone know anything about working in Carbon Fibre?
i thought you need a vacuum to fix the Carbon and glue to each other. you don't want delimitation as that weakens the product. I think autoclave might just for speeding things along
Hi all
Hello! New member
baz, clean bike you have there 👍
- I'm done!
Greetings from a new guy
XS400 DOHC Carbs
i have done it but the doc carbs are different width, been a few years since i did them. had to weld a tab to connect up the carbs' butterfly I had pods on too so guessed the jet sizes. think i used the original carb size for mains.
YOC Meet 23
I'm camping with scouts that weekend :(
hello
Hi (again)!
back Sacha, great you are still around
XT660R -08 cylinder head crack
its on the waterjacket, but I recon it can be repaired. looks like it's been frozen with no antifreeze in
North Wessex Downs AONB
nice ride out. I got a pair of Altberg boots, they are amazing. Waterproof and Altberg can repair them too. As used by the police so comfy as fook. Got mine 2nd hand for £50 and they were like new https://www.altberg.co.uk/boots/all-year-round10/clubman-roadster-original
I don t know..
I'd go for the MT-03, more road biased and that seat on the XT, ouch
- Damnit drewpy!!!
YOC Meet 23
Tommy and I also went to Whitby, camped at Squires. visited all the sights and pickering to see the auction house. Some nice very roads near there btw if you venture out
Ferry , Newhaven to Dieppe
i take a piece of carpet, easy enough to stow away as its only around 6" wide and long enough to protect the side panels
'bout 5 hours for me or 3 and a bit on the motorway. tempted but a little too far for an overnighter
Tx500 Can’t get the points adjusted!
I'd start from scratch. make sure the valves are def on compression ie both loose on the cylinder and the timing mark is there. the LF (left fire should have the points opening, you may need to rotate the backing plate to achieve this, if not, then you are 180' out.
idle at 5000rpm
or cable sticking. if idle hangs, def too weak, if bogs too rich
