drewpy
Everything posted by drewpy
  1. the MOT merely states that the exhaust is not too loud and is the tester is deaf, then that's the way it is. I reduce revs on the tracker and have fitted a mirror just because of this. not been stopped yet!
  2. just another day in Bolton, what's the issue here?
  3. I did swear a bit watching this, this is pretty fast riding! and no sand pit run offs! <iframe width="560" height="315" src="http://www.youtube.com/embed/iGsTcmLG7dU" frameborder="0" allowfullscreen></iframe>
  4. drewpy replied to Paulwhite's topic in General
    hammerite seems to be the chosen budget paint. specialist thinners needed and not much colour choice but very durable!
  5. to the YOC Mr Burns
  6. wokring on the car today, and working at a wedding tomorrow. hopefully get a few hours on the bike this avvo.
  7. classic race game Wipe'Out in real life quantum levitation <iframe width="560" height="315" src="http://www.youtube.com/embed/Zqmdv5iyIOY" frameborder="0" allowfullscreen></iframe>
  8. drewpy posted a topic in Video Section
    this is in 3d. you need those red/blue specs that Kev always wears while out riding <iframe width="560" height="315" src="http://www.youtube.com/embed/fuZQ5_X38GE" frameborder="0" allowfullscreen></iframe>
  9. I'm sick them on my windscreen and I'm sure you are too <iframe width="420" height="315" src="http://www.youtube.com/embed/fHCLpsaKbZg" frameborder="0" allowfullscreen></iframe>
  10. let all sing now....Doors Doors Doors....<iframe width="560" height="315" src="http://www.youtube.com/embed/LohoUFGCJ8g" frameborder="0" allowfullscreen></iframe>
  11. if you have the electro mechanical voltage regulator, you can adjust it. you need a healthy battery to have good charging as that is the way the system works. you have 3 white wires from the stator to rectifier and 2 green from the field coil. the field coil is fed by the voltage regulator and is really an electro magnet and more or less current produces the right amount of charging for the battery depending on its state of discharge!
  12. drewpy replied to sniff6's topic in Video Section
    good short, I just kept thinking why didn't his hat blow off at those speeds then it irked me!
  13. mines fine, in fact its better than some modern bikes I've ridden! to get to 2nd to 1st, you have to push down twice, not jump on it to get it there. There is a pawl and ratchet which has to return to its central position before hooking onto the next gear/neutral position. A loose rear drive chain gives the worst gear change
  14. Ken, good to have ya here mate
  15. the woodruff key is only there to locate the rotor. Its the taper that grips the rotor and some peeps use grinding paste to get a good key and thus grip (wash off the paste first)
  16. 1985 xs250? never heard of them. plenty of spares around. cmsnl.com in Europe. yam aha still sell a lot of spares eBay is also your friend. I would up jet the mains at least 2 levels.
  17. don't understand your English, sorry
  18. getting there Pat..
  19. drewpy replied to drewpy's topic in General
    I had a party in outer space.... it was shit, no atmosphere at all!
  20. I'm really good at dodgems, its like a precursor for riding a motorbike.
  21. drewpy replied to rossr's topic in Yamaha Workshop
    when I rebuilt my engine, I used a mineral oil to enable the rings to bed in as synthetics don't provide the right properties to enable this. I also thrashed it for 20 miles then changed to a semi synth oil and its been fine ever since (6 years)
  22. drewpy replied to drewpy's topic in General
    coz I'm too busy figuring out your problems by scratching me head
  23. granbys, depending on age, motoward, wemoto, govners bridge, esb.
  24. I thought the neutral wire went to Switzerland
  25. drewpy replied to drewpy's topic in The Bar
    in your case it fits over your mouth
