drewpy
Everything posted by drewpy
  1. I had chips for tea, very nice post an intro mate, lets know a bit about you first
  2. drewpy replied to drewpy's topic in Projects
    Question; the original coils I have are 2.43 to 2.97 ohms and suit the original ECU the '91 xj engines have 1.8 - 2.2 ohms, anyone think it will fry the ECU? ( it took me 6 months to find one)
  3. drewpy replied to drewpy's topic in Projects
    put in a 95 mains in today and...spot on sparky is a nice brown colour went for a little ride, its quite loud so turns heads and I have to get used to this changing gear routine too, up and down the box all the time. I think the running jet is a bit too large now, but I'm on WOT all the time anyway! still need to sort out this dragging clutch as its hard to get neutral and you have to rev the engine to stop it stalling.
  4. drewpy replied to drewpy's topic in Projects
    i went to do a bit more on the FZ today.... ....and I just thought sack it. and changed the engine over so the new engine is in so I just need to put new needles in the carbs (£52 EEK!) and fire her up (hopefully) the new reg/rec arrived from China too, happy days
  5. that sheathing looks like a giant femidom
  6. have you looked in the 400greybike forum? http://www.400greybike.com/forum/viewforum.php?f=48
  7. if you can get them for £40, I'm all ears
  8. it all goes around the battery tray. battery in the tray depending on model rectifier under the tray, regulator to the rear of the tray flasher and cancellation switch on the front starter rear of tray to the right
  9. hooters the boobie place?
  10. I would have thought, gas flowed head, skimmed to raise compression, slotted cams, beehive valve springs, race exhaust, FCR carbs, dyno jet, about 30 hours on dyno to dial it all in. that's about 1.5k's worth there, want to go further?
  11. thanks tommy, sound better too. makes loads of 2 smoke noise as I whizz past at 20 MPH
  12. yep, i think it was the cover screws, been a while since i had mine off
  13. drewpy replied to drewpy's topic in Projects
    new jets arrived today, hopefully the weather at weekend will be kind again and get the thing jetted correctly
  14. I'm sure you can get a cable made up. loads in the UK but don't know any in the US. have you tried yamahatopdog they stock everything loads on eBay, unless your too tight http://www.ebay.com/sch/sis.html?_nkw=YAMAHA+LOWER+THROTTLE+CABLE+DT250+DT+250+1975+1976+&_itemId=251084103421
  15. looks cold with the snow, but looks like it was fun
  16. drewpy replied to drewpy's topic in Projects
    no, YND its a 1973 Manchester number only 1 registered owner, me
  17. there is another thread on that
  18. very nice
  19. only works for the English John the long screws fit through the cutouts and keep the stator from moving around
  20. they got over 10,000 sigs and DVLA replied, basically saying the C0 data is not recorded for bikes so the fairest was was to tax on CC''s go figure
  21. Stator seems like it will fit NSD Glad the site was useful PreLoad
  22. use youtube on the telly, best way to view. ( I used the mobile to search though and link up to the box) Mags? depends what your into, if you want tips, get the police motorcycle book. Might not make sense at first but it'll click into place when you ride.
  23. ..to tears
  24. what if he picks his nose or wipes the seat off his forehead or has a scratch? eh eh!
