.jpg.5c05eb7af257e741ca000bd984024429.jpg)
Everything posted by drewpy
New ybr 250 owner
Dec, I suppose Ant will be on his way?
My '87 FZR1000 Genesis...Oil cooler?
fz600 have oil coolers, its basically a screw on part and i converted mine to a spin on filter from a xjr400
you can use an infrared thermometer too. very handy for diagnostic and for covid19
XJ900f Engine Builder
good info, did you have to machine pockets for the valves?
stuttering engine
check inlet manifold for cracks and leaks by spraying easy start around there to see if the revs rise.
- Newbe from the UK
Road Tax refund - laugh or suspicious?
just keep it, not going to make a difference in the millions the DVLA take.
Yamaha Fzr 1000 engine compability
wow, I've spent a small fortune on just the top end of my TDM £90 just for a head gasket and that's for a twin cylinder bike.
Hi from Miami!
to the forum I too own an XS400
Virago CDI
An alternative is to use an ignitech unit
Hello from Vietnam
there's a technique to it, you don't want all power straightaway but a gradual process. I did mine so the leading edge touched fractionally before the rest
Hello from Vietnam
, Colin. love the tls front brake
- Tzr2502ma
Bike bog on throttle, lean or rich?
but there's air bleed jets surely? if they are blocked, then it'll always be rich
i didn't mean the jets themselves. more the carb body internals where the jets fit into
XJ600 scrambler
if you get desperate , you can use these guys http://www.carmoelectronics.co.uk/index.php?main_page=index&cPath=497_514_2129_2915
XJ600 scrambler
maybe your TCI has gone. have you ensured the earths are clean from the battery and to the engine. Switching on and off is the work of a simple contact set, that's why I'm looking at the TCI having issues. If you look on the TCI there is a TID number, try and borrow one of the same type to see if its that good look with the build
are the carbs clean inside, ie all the small jet holes unclogged?
Hello from Estonia!
1998 XJ600N - Stiff Clutch
lube your cable if its not a slinky coated one, or just replace it. Readjust the cable and check the run is not near an exhaust pipe where it will burn
Front Brake master Cylinder
it also depends on the handle bar shape. American bars tend to have higher, curvier bars so there are shaped to meet those curves. TBH so long a the bore size is the same, you should be ok. try xs650 stuff off mikes XS
What a faf.
I never forget undoing a cam cover bolt on the FZ using a ratchet ring spanner. going great till it hit the frame with no where else to go. had to cut the spanner with an angle grinder. I feel your pain
I'm suprised its finicky then. I'd still check timing, fuel height, valve clearance . before you start on different jets. BTW fuelling the top end still applies, get that right (over 3k) there' usually a transition around there from pilot
check timing if its adjustable first. check 2 stroke oil as too much weakens the mix you need a jet kit, allens or NRP, you need to ensure mains set first for WOT, do plug chops to check mix. I assume the carb is set up and cleaned throughout?
Dan, XSR 900 Abarth
the xsr looks great
