Everything posted by drewpy
1984 XT125 kickstart issue
see Allen Millyard's youtube channel and say casings can't be welded. I've had a motor mount welded up and its no problem for 10 years its been on there. You need too make sure all oil is out but some castings can be porous and there may be an issue
Aerox modding help needed
I think you need to get it on a dyno just to check fuelling and see the power curve. will save a lotto time in the long run Run it in first though as dyne's are brutal
girlie night out
Two wives decided on a girlie night out. On the way home they needed a pee and nipped into a graveyard. Then they realised that they didn't have any wipes to finish up, so the first one used her knickers, and the second one found a wreath and used that. The next day one husband rang the other and said 'No more girlie nights out, mine came home with no knickers on'. The other said, 'Well if you think that's bad mine came home with a card in her crack that said 'From all of us at the fire station - we'll never forget you.''
New to the forum, 2017 Tracer 900 owner
my mate has the tracer GT
Hello All from North London Xvs 125
(really) Basic Tank cap replacement question
usually a captive nut, even if it did fall in, just use a magnetic aerial thing to fish it out
YOC 2019 Meet
I'd love to meet up again. going to be a strange year though I think.
Hello everyone UK based in Essex
Headlight area diode.
very simply, a diode is a bit like an electrical valve, it lets electricity flow one way and blocks it going the other way. stops damaging feedback to other electrical systems
YOC 2019 Meet
- Hello From Texas
Sorry, but just can't help it.
i know it was, hence the emoticon it was shrek
Dr and the medics
1980-G DT175MX 2-Stroke Oil Leak (US Model)
it was me, I did leave a note but it didn't process.
Quarter turn/quick action throttles
I think I adapted my throttle tube on the FZ to make it more quick action. I'll have a think on what I did or where I got the info from found it, i grooved the pvc to keep the cable from jumping off (it never did but I felt it needed it) https://www.kawiforums.com/threads/quick-turn-throttle-mod-with-pvc.122605/
Yamaha Majesty YP250 - Exhaust hanger main bush has play
looking at this fiche, its a bearing https://www.fowlersparts.co.uk/parts/4012594/yp250-5sj2-2002-060-a/rear-arm-suspension should be able to buy from a bearing supplier if you can get the number off the bearing it self. heat up the alloy first and press out straight. oil seal will pop out using a small pry bar 93306-302YK
Have a good Christmas all
Merry Christmas everybody. Family still Covid free (a few on front line police force too) Stay healthy 1f14a9be-1691-4cd8-9b03-ff3e87a1c5b2.MP4
needs a caganer
Hi from Berlin. A new-to-me RS125 arrived. Yeehaw.
you take my breath away, a good group. what do you play?
XS 360 Will not start
usually carbs and their ickle drillings try some easy start down the carbs to see if she fires up, then you have your culprit
- Piggie wiggies
Piggie wiggies
mike, you can't connect to a WhatsApp image. you would need to download it or take a screen print first
Another New Member
Hi from Malta
Foamy's New Toy, XJ650 Turbo :)
bloody hell, all we need now is AndrewElvis to make an appearance
