drewpy
Everything posted by drewpy
  1. Kon, there are a few xs250 owners on here but not heard from them for quite a while. is it the early SOHC or the rare DOHC model? 400's share the same running gear
  2. can't be worse as it bottoms out with just me bouncing on it
  3. ok thanks for the heads up, just wantng the spring ATM as I've spent loads and just wanted to get the spring and then overhaul the shock over winter
  4. to the yoc. pictures or it didn't happen
  5. I don't know, hindsight is a great thing to have and that was a long way to reverse. If you see someone reverse it's like " what's he doing?" then it "hello!!" then "WTF" .
  6. put an inline filter on it too, as the tank may be full of rust dust
  7. I would be a bit more patient and get the proper one. I have 3 ignitors for my fz "just in case"
  8. hi Folks, I'm trying to get the measurments for the R6 rear shock spring so I can get one made up that is stronger. does anyone have one off the damper and can they measure the internal diameter and length please? ta velly much Drewps
  9. I use a free LG app on my phone, easy to navigate and uses a touch pad for the pointer.
  10. very nice
  11. that's why i have the missus as pillion
  12. back ricky doodle
  13. looking good, like where you are going with this
  14. I scrapped it on the end I used a freezer spray (actually dust buster upside down) and sprayed around the edge of the screen. If the panel was faulty the picture would come back. It did which suggests the panel has broken and was too expensive to renew. I since bought an LG 47" smart TV, which is very nice thanks for your ideas though
  15. drewpy replied to meatloaf's topic in The Bar
    I googled it and here it is, very comfortable
  16. I'm still waiting lol
  17. mikunis are notorious with their tiny fuel galleries. I hear peeps say they are clean, but all they do is use a tooth brush on the outside. can't believe you haven't sonically cleaned the carbs down as that would be a priority. new jets and gasket kit (from Allens performance) factory setup with standard filter modern fuel id really shite and gums up a carb within 2 weeks if your unlucky I now put premium fuel in my carb'ed bike as there is usually less ethanol content
  18. buy another bike of the same colour, she'll never know the difference
  19. that first owl noise is just some bloke with a blade of grass between his thumbs
  20. was just about to suggest that
  21. In gear?
