Everything posted by drewpy
Old stock and parts suppliers
ypvs stuff fit too and there's plenty of spares being remade. Just got to look at the part and check. I converted my shock to R6 and used YVPS wish bones to raise the height. Xj600 stuff will fit along with FZR400 the 600 was based on (not the alloy framed ones)
New helmet.
no, he's been quiet on facebook too
- Hi from Shropshire
New helmet.
Its ok, I work in Bolton so could try them on for you 😅
Stainless Steel or Titanium bolts/studs?
I've replied via Carpe site :)
I use these guys for years https://www.a2a4.com/acatalog/ENGINEERS_STUDS_A2.html
YZF1000R Thunderace!
I suspect it was my laptop that didn't like me putting thunderace in (had to try 3 times for the last one) yes its supposed to be like suede
I guess not many posting have thunder races. as for seat material have you tried alcantara? its like a swede but manmade
I've used stainless studs before. they can vibrate out being so hard but a dollop of stud locker sorts it out. I'm a fan of brass nuts though, no reaction to steel and stay on too
Hi from the new forest -xvs1100
- Basic's
could be anything, emulsion tubes wear in the carbs, coil leads break down on these bikes. tried new (non copy) spark plugs?- YOC 2019 Meet
- XS250
- Crank Case Repair.
Atherton is just outside Bolton, Dan is the man https://www.a-c-eltd.co.uk/- Crank Case Repair.
sometimes a marketplace search on facebook reaps rewards. I know of kickstart motorcycles in Manchester (If they are still going) they did some welding for me. Atherton Creative engineering do ally welding too. I got them off facebook Not in Yorkshire though- pissed off.
- 1971 ATI 125
you can get the dogs recut as race peeps get theirs undercut to lock the gears together under acceleration.- pissed off.
sh*t man, that's crap Why can't peeps be upfront rather than try and spin a yarn? Is it worth going round to see him after march 29th? face to face makes a difference to how peeps are motivated and you may get a better response- Thinking of changing the FJR.
A good channel to watch on youtube is Missenden flyer, he does some good reviews https://www.youtube.com/watch?v=RrzeoZuii0M Hope you are OK now Slice?- You have got to be shipping me!
is there an appeals process?- My poor bike is suffering...
best to coat the bike (not the brakes) acf50 or i have scott oil 365 it'll keep corrosion away and protect electrics too. If corrosion has got under the all coating, then it needs to come off, no other way. just use peeks or if its really bad, solvo autosol- am6 crank seals
I remember when I did the Gilera , i had plethora of pilot and mains jets. and just kept swapping till I hit the right combo Also the height of the mains needle makes a difference- am6 crank seals
crank seals will have hardened a bit, but as its fine when warm, I would think that's fine. Could be a bit of crap in the carb pilot system for low running. was the bike stored with the carb and tank dry? was there a fuel filter fitted?- Aerox modding help needed
its 4 stroking lower down, if you've pushed the power further up the rev range, that's where you need to stay. You can't have more power and expect it to perform all throughout the rev range, its a compromise. have you tuned your power band into when the rollers bite?- 97 Yamaha thundercat 600 rear axle problem
Don't know the thunder cat per se, but there could be up to 3 spacers. 1 twixt left sprocket carrier and swing arm 1 fits inside the left bearing between sprocket carrier and left hub bearing, looks like a top hat and most peeps throw these away when renewing the bearing as it is drifted into it. 1 in-between the hub bearings maybe 1 right side which usually is the calliper mount - Basic's
