drewpy
Everything posted by drewpy
  1. aboard post your Q in the classic or workshop section
  2. drewpy replied to drewpy's topic in Projects
    Just done my cam cover in VHT crinkle finish looks the dogs B
  3. Yamaha have set-up a Yard Built dealer contest to promote a bit of healthy competition in their network. Best bit is, many of the parts developed and used on these bikes will soon be available over the counter.
  4. did you try to pushjovert the kickstart with the clutch engaged so it eliminates the valve train as I suggested earlier?
  5. have you double checked valve timing? it can be easily 180' out
  6. drewpy posted a topic in General
    Hey Guys, Just bought a Mobius cam from Banggood UK warehouse. http://eu.banggood.com/Wholesale-Warehouse-Mobius-New-Version-Wide-Angle-Lens-C-1080P-HD-Mini-Action-Camera-wp-Uk-966178.html got it for £50 and is a cracking little action cam. just ordered a waterproof cover and a mount which goes on the rear mirror stem from Joovuu (stockport based) https://www.joovuu.com/gb/mounts/159-motorbike-mirror-mount.html?search_query=mirror+mount&results=1 .loads of parts available dead cheap and loads of accessories too. when it comes I'll review it and obviously take some footage (maybe sunday going to the show)
  7. drewpy replied to lallasro's topic in Projects
    nice one lassy. got some work there, but I'd service her and use for the summer and see what else needs doing
  8. you'll need AC bulbs as LED 's only work in DC mode. just saw a film about Tesla, very interesting
  9. was it free?
  10. drewpy replied to slice's topic in Yamabyss
    never mind, just think about this time next year when its all in the past I'm still waiting for my rear shock to be finished. They are having issues taking out the bushing due to it being there for a few years and a 40 ton press won't shift it! can't do anything else till the shocks fitted
  11. ouch! may be try it with the clutch in, it won't kick over the bike but just spin the clutch basket. just in case the top was not timed properly
  12. What he said ^^^
  13. shouldn't watch it whilst doing the dishes Kev
  14. only better when the kids are off school, tells you something about today's parents. I hardly ever took mine to school, they walked or took the bus
  15. hard to tell via text, sounds about right what you say. maybe try and do it again, you don't need to drain out the oil, keep the bike on its side stand and the oil will drain to the left. (thats why I start the bike upright so the oil pump gets some oil to pump) just don't try and kick over without the cover on as it will snap the crankcase bearing in the gearbox and will scrap the cases.
  16. is the side cover fitted? I always have issues getting the kick stop and gears to mesh when putting in the kick shaft. Its usually trial and error for me and I've rebuilt 3 engines
  17. geeze, shit happens man. good opportunity to buy some new stuff
  18. yep, CDI went out early 70's could be either the ignition caps or leads if you can get 1 and 4 to work
  19. do you have a spare TCI?
  20. schedule is now out http://www.iomtt.com/Classic-TT/Classic-TT-Schedule.aspx
  21. therm shock will get them off as Slice suggested, heat,then cold ad infinitumn. should come loose eventually
  22. these have one pickup coil. its a wasted spark system so 1 and 4 cyl sparks and so does 2 and 3 so I'd look at the coil. First look to see if 12v is reaching the coils with the ignition on. The TCI earths to ground to complete the circuit, also check the HT caps as they fail too. I assume you've swapped the plugs in case they are faulty?
  23. it depends on which year is your xj, the '91 has one pickup coil, earlier ones had 2.
  24. my mate was part of the Lymn show, I did the older venues, but never went to the Barn Owl (I might shut it down like the others) RC31? nice
