Everything posted by drewpy
Hello everyone I'm Jason.
Jason
XS250 starting problems
good batteries should be on 13 volts, yours is below that. 13.4 running is ok for a 11 volt base line. Its a field coil system so the battery creates the magnetism, low battery, low charging output
been thinking of paint for my bike
i prefer the white seat too. have you lacquered it yet?
Vmax question. Carbs/carb?
post it up Jim, sounds interesting
- FJ1200
put it on a trickle charger, keeps them sweet glad you sorted it
To Triumph or not?
if you lock a dog in the boot of the car, he's still happy to see you after a few hours On the other hand if you locked the missus in there......
could be, batteries don't really last all that well in a motorcycle
on the float bowl, see the little drilling on the lip? shoot some carb cleaner down it, thats the choke route.
Project Jennifer
I'd dry build the bike and get it outside and see where it takes you
What kind of engine do I have?
- Facebook blackmail.
Pasty and Peas Bike night
Great night and good to see you all. could see Blackpool tower in the distance and someone was in a hot air balloon going for a flight the bandit was nice Kev, shame you broke his tail unit getting on the wrong side
so you have the 250 carbs then. you need to confirm that they have the 250 jets in. I never trust garage mechanics tbh, its not their bike and usually give those jobs to the "Saturday boy" you shouldn't need to prime the carbs, its on a vacuum tap which lets the fuel flow. check that fuel does flow if you need to do this, could be partially blocked. make sure you have an inline fuel filter too
Facebook blackmail.
A few of us are on facebook welcome to the 21st centry
Squires 2015
not sure what I'm doing yet. only would have just got back with Tommy from the IOM ManxGP. I'll have to let you know thursday
are the carbs' choke a lever or a pull to operate? I assume it eventually starts but how? fires on 1 cyl and then 2 chimes in or does it get straight to it? I'd suggest looking at your timing first, that's clean contacts, contacts gap, take off left cover and find LF to check ignition timing. (even better use a strobe) and check RF timing if the bike has had a 400 barrel and head on, the carbs will have had the mains and pilot jets increased so you need to check if they have the correct ones for the 120 and also check the needle position and type. that'll do for starters
Yamaha XS250 starting problems
to the YOC
Project Jennifer
ignore them Slice,spambot invasion. unless you like a trojan on your PC don't open them
Project Jennifer
try a2 a4 fixings, good website and the cheapest I've been to. no kits but I'm sure you can use a vernier caliper
A pub near Matlock for camping ??
you produce wet ones..... from your arse
Summer ?????????
oh no., that means its gonna start raining
Fz600 Gulf
showers? what are those?
VJMC Bhurtpore Inn show 2nd August
Had a great day out with Tommy XS. There was quality bikes on show and lots of them. Food great and very friendly peeps there. Met a few guys off aircooled forum and the RDLC forum too. Tommy chatted up a dog pace bike for cyclists talked to the organiser and he brought this one for Lassy
