drewpy
Everything posted by drewpy
  1. drewpy replied to drewpy's topic in Projects
    I'm thinking TCI now, got 2 spares to try and I'll double check cams etc.
  2. drewpy replied to drewpy's topic in Projects
    its not! got some running issues; Starts quickly with no choke and then picks up all the cylinders but have to use 1/4 throttle to do this high RPM when warmed won't rev over 6k and makes a funny noise if I push the issue spark plugs suggest rich mix before carbs rebuilt, no air leaks I'm just wondering if the skimming has affected the running ie too high compression or I've mistakenly didn't do the valve timing correctly (checked and double checked through during install) anyone comes across this or give me some pointers please? had the carbs just rebuilt and setup by NRP so no issues there. compression check next and probably recheck valve timing and gaps might have to go on the tracker, which is running great
  3. Dave, great read and if you need how to do the clutch, I posted it in the forum somewhere. Uses a pre-BMW mini door pin cut down and re-drill (dead easy compared to what you went through) I thought about getting an Ignitech but the price I have an FZ600 but have fitted the '91 engine, also check the primary gear near the clutch, mine was wobbly loose. there is a vibration around 5 - 6k on these, but its called character
  4. drewpy replied to balaclava's topic in Classics
    thought it was a greek sweet
  5. I like a god fettle meself
  6. drewpy posted a topic in Video Section
    last saturday a hole appeared in the main road in Manchester. some guy got his drone out to check it
  7. Went to Southport this afternoon to test the camera out. bloody thing fell off my helmet, luckily just turning a corner at traffic lights in Lord street and can say its fine. they have a satin rubbery finish on the case which the velcro didn't stick to very well. i also forgot to set the mode so I have to crank my head over 90' to watch it anyway was a good ride out and I learned a lot (what not to do)
  8. drewpy replied to lallasro's topic in Projects
    looks good Lassy, well done! called spire clips http://www.ebay.co.uk/itm/10-x-Panel-Fasteners-C-Clips-Spire-Clip-Stainless-Bolts-Motorcycle-Fairing-m6-/131379265783?hash=item1e96d080f7
  9. well its on iplayer ATM
  10. drewpy replied to Noise's topic in Projects
    sounds great, he has a website and seems a down to earth guy http://joebysairbrushart.co.uk/gallery/completed-bikes/TRIUMPH OF DEATH.jpg those finned covers,Mike bought a set from a Thailand eBay seller £60
  11. Dave you watch the UGP?
  12. drewpy replied to drewpy's topic in Projects
    having the carbs pro cleaned, they must have had residue in storage so picking up friday and try again! Pics to follow
  13. drewpy replied to lallasro's topic in Projects
    I use astonish and even Tommy will testify how effective it is. just spray and wash off with hose, don't leave on too long though
  14. most of the yam cyl have cylinder liners and if you do get them replaced ( I did on the fz600), you need them skimming also to bring the deck inline
  15. some peeps have left them in ok. you can get them (I had a set and sold them on) but they need destroying to remove I just sprayed mine in PJ1 and they looked great
  16. drewpy replied to Rey Padojinog's topic in Forum Help
    seeing as this is the only post you made, just make another profile
  17. self cancelling won't work though
  18. drewpy replied to lallasro's topic in Projects
    I'd get the coats professionally laquered so they can get a few coats on there and then cut down. should be the dogs danglies
  19. wemoto, yambits, fowlers online bitsforbikes try fowlers first as they have an online fiche and have genuine yam products
  20. nah, keep it on the main stand, a little oil will weep out. I'd get a gasket for that cover too.
  21. more info http://www.visitisleofman.com/lib/docs/tourism/iomfomeventscalendar2015.pdf
