drewpy
Everything posted by drewpy
  1. drewpy replied to drewpy's topic in General
    wow, we are on £60 already, thanks
  2. drewpy replied to Royston's topic in Projects
    depends if the trike frame was built around the right engine case, usually very easy to get to
  3. drewpy replied to mike1949's topic in Random
    I've just moved it, can you write in here now?
  4. drewpy replied to drewpy's topic in General
    thanks for the donation guys so far we have £30
  5. drewpy replied to drewpy's topic in General
    Paul's family said any donations to cancer research please just setup a just giving page. Can we reach £100? https://www.justgiving.com/andrew-Scialpi-Sullivan
  6. drewpy replied to mike1949's topic in General
    there's a series on at the moment. Quite interesting actually
  7. drewpy posted a topic in General
    It is with sad tidings that Paul Brown AKA Oldtimer, passed away a couple of weeks ago I've only just got a text from his Son, Nick and his funeral is at southern Cemetery, Manchester Crem this Thursday at 10:55. A lot of peeps on here have met Paul, mostly through Squires the past few years and he only recently he had to give up his bikes due to ill health my thoughts and Prayers are with his family. RIP Brownie BARNSLEY MOTORCYCLE FESTIVAL 29th JUNE 2014 Manchester Salvation Army Toy Run 2011 19th November
  8. has to be genuine Yamaha manuals, usually near the back
  9. I would call then vintage, that's usually flat tankers, but they are very nice and I do appreciate all bikes
  10. all the yam manuals have routing for pipes and cables, very useful. if your bike is a keeper, its worth investing in one
  11. drewpy replied to mike1949's topic in General
    should have bought the other one off her for 50p
  12. drewpy replied to drewpy's topic in Projects
    Cheers Paul that's the issue with faired bikes, the bike ran even better on the way home, just ran the bores in I think cheers Meat yes, nearly rammed into the back of you a few times. Hope the weather is better tomorrow, need to practice loading up and need to change the oil too
  13. very nice, must do abroad sometime
  14. drewpy replied to bindie's topic in The Bar
    Lovely bikes the trumpets, your most welcome on here and let us know how you get on. a pikkie please?
  15. the 2 smoke guys are actually going to go further to Scabs if peeps are up for it. The start time has been brought forward to 12 noon from 2pm
  16. drewpy replied to drewpy's topic in Projects
    also went out with Tommy to suss out the timings for the ferry at Liverpool
  17. Hi
    drewpy replied to Robin B's topic in New Members Welcome Area
    rob. where are you in the north?
  18. drewpy replied to drewpy's topic in Projects
    you referring to the XJ forum?
  19. aye, you not been out for a ride with us yet, what's the craic?
  20. drewpy replied to lallasro's topic in Projects
    the thing with Yamaha parts and all the big makes, they utilise a lot of older parts, just change the codes around. I buy stuff just by visualization and hope they fit ( mostly right)
  21. drewpy replied to drewpy's topic in Projects
    well I've finally sussed it. As usual it was a few things; 1) the exhaust cam was 1 tooth out 2) A few valve gaps were out of specs (poss due to the head bedding down) 3) re torqued the head down and it took another 1/2 turn to get the necessary torque thanks for your input fellas! it revs out and so much better the engine is a '91 xj600 in an Fz600 chassis. well I've finally sussed it. As usual it was a few things; 1) the exhaust cam was 1 tooth out 2) A few valve gaps were out of specs (poss due to the head bedding down) 3) re torqued the head down and it took another 1/2 turn to get the necessary torque thanks for your input fellas! the engine is a '91 xj600 in an Fz600 chassis. well I've finally sussed it. As usual it was a few things; 1) the exhaust cam was 1 tooth out 2) A few valve gaps were out of specs (poss due to the head bedding down) 3) re torqued the head down and it took another 1/2 turn to get the necessary torque thanks for your input fellas!
  22. watch that program, so I may see the Capt
  23. the last one is a viral ad for planet of the apes
  24. drewpy replied to drewpy's topic in Projects
    one was for the issue I was having last year and the second coz it was only £10. pissing down tonight so couldn't do anything
