drewpy
Everything posted by drewpy
  1. you might not be able to replace the leads, because they can be glued into the coil, depends on the model. As for tank, one bolt at the back and "wiggle" the tank towards the back, lifting the rear of tank by couple inches. watch out as it will let go very quickly (held on with rubber "bungs" into frame) it will be easier to do the valves with the tank off. PS don't forget to undo the vacum and petrol pipe from the tank first.
  2. inlet 00.8 - 0.12 mm exhaust 0.16 - 0.20 mm drew
  3. try this link http://www.starmotorcycles.com/star/parts/home.aspx usa but you can see the parts you need. Iv'e used standard generic and stainless bolts on my restoration. try B&Q
  4. If you can get a larger nut over the bolt head, you can then weld it on inside the allen bolt (build up the weld to inside the nut). due to the different heat characteriscts of the metal, it will break any alloy corrsion. Then you can get a socket over the nut and turn. his also works on studs snapped off flush with alloy heads. You could also get a dremel and cut a groove, then use an impact screwdriver. BTW any bolts that are tight should use heat if possible and an impact driver. Drew
  5. if your selling the bike, put the old rings back in. Making sure you haven't mixed them up in the first place
  6. not sure about the xj's, but on my bike the gear shaft runs throught the engine to the other side. this then acts on two tentioned hooks which revolve a drum (that's your gear selection) If you have a similar setup (most probably) then you may have knocked the gear shaft slightly (usually they are fixed to stop sliding out, so the problem may have happened anyway) and somehow disengaged one of the "hooks". one hook makes the selection and the other returns it back. its worth taking off the casing to check operation. If you have a manual, have a look there first to confirm the setup. other than that, are your splines ok and not slipping round from the lever action?
  7. this sounds like its the same problem on both counts. All hydraulic master cylinders have a tiny return hole within the resevoir and if this is blocked or partially blocked, won't return the compressed fluid back into the resevior. This will lift your clutch plates away the more you use the clutch (causing slip) and then eventually pop out the clutch piston.
  8. Evilbay has loads. You are best to at least get the bores honed (45' crosshatch)and new rings, but you need to measure the bores first(i'd get your local machine shop to do that accuratley) to determine any wear. try www.Motoward.co.uk give them a call on 01403 824222 they have computerised OEM stock and are really helpful, and suprisingly cheaper than evilbay on some items motolink @ www.yamahaspares.uk.com if you are looking for any 2nd hand spares i have a 250 engine partially stripped in my shed
  9. drewpy replied to r75/6's topic in Classics
    have you tried this site? http://www.yamaha-xt500.co.uk/portal.php they have sr's on there, not sure if they are the same tanks tho'
  10. I used a hair dryer up close and they came off luverly using a finger nail to lift then pull/tug off if you mean badges, then still try the hair dryer method the graphics will of course be stretched and can't be used. use solvent to take off the remaining glue
  11. drewpy replied to Robbie's topic in Yamaha Workshop
    ahh you said you had no compression tho'
  12. drewpy replied to Robbie's topic in Yamaha Workshop
    what do you mean "no compression"? how do you think this is connected with the starter? have you tried bump starting the bike?
  13. may have distubed rust or crud in the tank and its got into the carbs. just a thought
  14. they are from an xs400/xs250. are they NOS or used? drew
  15. triple s plug all the threads for you as part of the service
  16. if you buy Classic Motorcycle Mechanics they advertise in there and you can get 5% off with the ad, at the very least you end up getting the mag free
  17. I used triple s in bingley http://www.triple-s.co.uk/ they have an online price list, do a superb job, just degrease your frame and swing arm and they plug all your holes and blast and paint it. Classic Motorcycle Mechanics use them a fair bit. drew
  18. cheers, that sounds right to me, I'll splice it into position 3 of the ignitin switch.
  19. Hi There folks!! Nearing the end of my restoration of the xs400. everything is wired up except the pilot/parking bulb (UK model). I bought a NOS ignition switch and it only has 3 positions as opposed to 4 on the original. This means that the connection to the bulb is missing. Now to the question; When does this bulb light? ie when the main lamp is on or when the key is left in the parking position (or both?) How does this fit in with the MOT regs? Cheers Drew
  20. Every one knows that Yamaha use its parts bin for different models! Just came across this on ebay, http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=34238 i have'nt used it, but the www.yamaha-xt500.co.uk/viewtopic.php?t=1230 have and says its great! you type in your model and you get all the common parts from other different models, so an sr500 part may fit but with a different part number.
  21. a relay work by energising a "plunger" across an even thicker wire in order to connect up the starter motor. I would think you only interupt the thinner wires which energise the relay as the current draw for the starter motor will fry the wires as it will be a big current draw. the ignition is usually a separate circuit, unless you mean key switch/ignition to recap thats two thinner wires in 1 positive 1 negative and a common colour in and out for the starter motor I hope i make sense
  22. drewpy replied to rf9rider's topic in Yamaha Workshop
    Found this guy on ebay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...=ADME:B:SS:UK:1
  23. I use www.motoward.co.uk but they are mainly for classic stuff. give 'em a ring tho', you never know
  24. drewpy replied to drewpy's topic in Classics
    Thanks, good idea regarding the threads but my original question is... how do i repair the prongs/and or what glue should i use? any ideas?
  25. drewpy replied to drewpy's topic in Classics
    Does that mean the prongs should be sticking out horizonal, or near closed? Here's a picture of the base with missing prongs. can I repair them or do i stick the seat with glue after powder coating?
