drewpy
Everything posted by drewpy
  1. drewpy replied to deb's topic in Yamaha Workshop
    try this http://www.aircooled-rd.com/ forum section, page two (as at 5.05pm 24/5/06), titled wiring in kill switch? hope that helps
  2. you havn't been doing stoppies have you? this really knackers the front forks up as it puts way too much strain on the fork tubes and wears them out pretty rapido!!
  3. drewpy replied to drewpy's topic in Classics
    Just got back from VJMC Nabs head show near Preston UK, and received 3rd overall for best in show! As you can imagine I'm dead chuffed
  4. far as i am aware, the sr125 is built to have 12hp, the only other way is tuning it. easier to buy a bigger bike like sr250 or sr500.
  5. depends how long they want the bike from you and if it is damaged, who pays for it? Also will the engine be underwritten for damage testing a non standard exhaust (and your warranty will be void forever) just my 2p's worth
  6. what's the first 3 digits on the engine number? I must admit i've never heard of an RK suffix. This is all i got http://www.vjmw.org/yam_id.htm
  7. also Motolink,motoward, speed sport in america. all online
  8. yep, its got loads more info than clymer and haynes (that's why I bought one, and got it from the states) Is it worth it? it was for me and depends on how much your salary is! there may be better examples out there (mine was new for instance)
  9. this is the one i got http://cgi.ebay.com/ebaymotors/FACTORY-SUP...1QQcmdZViewItem. on ebay now. bit grubby but saves you trying to keep it clean
  10. Ebay, I got haynes. clymer and the official yamaha (the best)
  11. If your putting oil down the bores and spinning it over, watch for oil spraying out. It's just put a couple of squirts in, kick it over on the kickstart and leave to seep into the piston rings in case they are gummed up. Then i'd start trying to start it after a couple of hours. Your igintion timing might be electronic judging by the year, so it shouldn't be an issue unless its been tampered with or the cdi has gone AWOL.
  12. Hi, and welcome. The SOHC xs400(and xs250) models have their camshafts run in the alloy head. These need fresh 20/50 oil. You will need a new (Yam) oil filter to go with the oil. Rubber perishes with age so you need new tyres and tubes you can't use a car battery and ride it, a new battery is only £20 ($$?) clean the air filters of spiders and dust, with compressed air check timing Clean out carbs lube cables spin up the engine with the spark plugs out to get the oil circulating first (And you can check for sparks at same time) any probs post in the classic or workshop section Drewpy
  13. drewpy replied to drewpy's topic in Classics
    cheers guys, did any of you go to Stafford on Saturday? I did see a blue ac-rd go by on the A34 towards manchester! anyones here?
  14. drewpy replied to Nick Frost's topic in Classics
    yep mine runs fine on unleaded
  15. I wouldn't trust it to glue. can you not get it tig welded till then?
  16. there's a bike breakers in farnworth, can you not get one from there? The Bikers Warehouse Ground Floor; Grecian Mill, Worsley Rd North Farnworth, Manchester, Lancashire, M28 5QW Tel: 01204 862832
  17. I get the workbench out, and a petrol can. Stick a length of pipe in the petrol and suck. When the fuel comes out stick it on the carb fuel inlet. voilla!! fuel ps everthing tastes like petrol for a day, but with the wifes cooking, that's a bonus
  18. Wow lots of questions and where to start; 1) pilot screws on mine are 1 turn out from fully screwed in +/- 1/4. don't over tighten or they might snap off the fine needle in the carbs 2) I got a spare 250 carb for spares if your desperate 3) I got a set of 4 indicators from Stafford for £20 and they look the biz, you can get studing from B&Q and cut to fit! 4) carbs need balancing 4) Try granby motors, Motoward and Motolink for yam spares 5) You need to thoroughly clean carbs of all gunk, in the end, i had to send mine off th JRS to be ultrasonic cleaned 6) You don't need to remove air filer to access any adjustments, they will be accessable from above (take off the tank) never run the bike without the air filters Any more probs just let us know! Drewpy
  19. drewpy posted a topic in Classics
    Hi, Just finished restoring my xs, and thought I'd share it with you. Mods have included twin disk with xs1100 master cyl and drilled disks all round. Just been out to Rivington today on it and it ran beautifully, can't wait till Stafford
  20. cheers, I tried Peeks polish with no luck. I'll try solvol
  21. Hey, Iv'e restored my xs400 for the summer and gave it its inaugral run yesterday. Thing is the headers have become discoloured and i was wondering does anyone have any tips on cleaning this up? I am useing the Motad system t the mo' and they use stainless steel pipes! I know about "Blue away" product, but is there anything else? ie cheaper Cheers Drewpy
  22. use copper grease on the threads next time
  23. You are best to get yourself a haynes manual for starters, that way, you will gain basic knowledge for your bike. try http://www.yamaha-xt500.co.uk/portal.php its mainly xt but the sr has the same engine as the xt. your seat should open by key, and them you will see the hinges. with the seat up you will be able to see a bolt or bolts to hold the rear of the tank on, then wiggle backwards off the rubber. you can see an sr parts catalogue here. try 1980 theres's an sr250 listed there http://www.starmotorcycles.com/star/parts/home.aspx
  24. I assume you mean spark plug leads and not spark plugs You can always unscrew the plug caps and get some shrink tubing from electronics store (Maplin out there?) then shrink it on the leads with a heat gun. As regards the kick-start, iv'e seen the gear mesh inside the casings sheared off before now, so it could mean an engine strip. Just bump start it, you sound like a big boy If your really keen, take off the right casing cover a check the kickstart shaft as it enters into the gearbox, you should be able to see it to confirm condition. as to the noises on your bike, I assume you have changed the oil and filter within the last 1000 miles?
  25. Damp in the ignition, drained battery, water in the tank if cap was off! take out the spark plugs can you smell petrol? connect up your spark plugs and earth to cyl head, do you get a spark? Charge up the battery drain tank and put fresh petrol in.
