drewpy
Everything posted by drewpy
  1. drewpy replied to curdy's topic in Classics
    easy, buy from here http://www.omarsdtr.com/homeend.html header wrap keeps the gasses hot and draws the heat away from the engine (and rider) that's why the're used, just gets mucky after a bit and have to re-do occasionaly Stafford this weekend, and weather's great...yippee
  2. drewpy replied to curdy's topic in Classics
    more
  3. drewpy replied to curdy's topic in Classics
    I like this one
  4. I think it is fuel starvation also. Check that the air can get into the tank when the fuel is used, as this could cause fuel starvation.
  5. drewpy replied to kev's topic in General
    thought I was nearly finished.................6 months later it was! keep going and make pretend engine noises whilst sitting on the bike, it helps a little drewpy
  6. drewpy replied to a post in a topic in Classics
    I think it was for audilble purposes as the silencers are shorter than my model I have the same engine and have no balancer pipe. drewpy
  7. The bigest size I have seen is 120x90x18 (on a spare wheel I had) but you fit it at your own violition and I am not recommending it per se!. I am running on 90/90/18 front and 110/90/18 rear btw writing in uppercase is considered rude, as you are shouting!!
  8. you will have to use european sites for 250's as they didn't have them in usa for standard rings http://www.cmsnl.com/searchparts_other.php...-01&make=YA £42.50 +vat and P+P I use Motoward as I get great service people have recommended granby's get yourself a parts book so you can give out part numbers, there have been a dearth of them on ebay at the moment £5 approx.
  9. drewpy replied to curdy's topic in Classics
    you need to tell us which model xs you have as there are about 4 variants
  10. drewpy replied to apathetic's topic in Classics
    no problem
  11. check ignition timing, valves adjustment and change your petrol (gas). if still not right do a search for carb xs400 as I have replied numerous time to this. Drewpy
  12. drewpy replied to apathetic's topic in Classics
    Hi, thought you had the carbs sussed! 1) the petcock has one supply from the bottom outlet going to the left carb 2) the connector at the back of the petcock goes up underside of the tank and to the right intake. this is the vaccum to operate the flow of petrol (gas) 3) there is a pipe link between the two carbs at the back, just above the float bowls, it also acts like a support between the two carbs so could be misconstrued as such, but is in fact the supply to the right carb. there's lovely for you!!
  13. your pilot system is blocked or way out of adjustment. mains take over around 4k, i had to have mine ultrasonic cleaned in the end
  14. OEM exhausts? forget it I had to buy a 3n6 version (nearly the last one in the world!!). the only way to go is sito, there is a distributor http://www.vyxxn.co.uk/ need to email them for prices and availability. I use motoward, cmsnl, speed sport, bike bandit, pgm (really RD aircooled but the 400D shares a lot of stuff) 400 is the same as 250 except for smaller bores and carbs and associated parts. get a parts book from ebay and that will help you identify the commonality. if you do find a new right oem exhaust (1U4) let me know
  15. why don't you ask the vendor, its that the xs400 needs 12v for the charging,it may have enough in the capacitor to start the process.
  16. the charging system needs a 12v supply to work. here is a wiring diagram could try this http://www.zeeltronic.com/page/bat_elim.php let me know if it works
  17. Take out the starter motor and chain (saves a few LBS) as the xs already has kick start, you don't really need to do anything else! If you're really finicky you can take off the starter solinoid from under the seat. As Merv said you coud use an rd right hand switch gear and polish up the casings as they are alloy!!
  18. try http://www.aircooledrdclub.co.uk/forum/ and do a search
  19. drewpy replied to allconfusedat39's topic in Classics
    depends on what tyres you have, manufacturers recommend different psi to standard
  20. drewpy replied to apathetic's topic in Classics
    the pilot system affects the lower rev range to 4k 'ish and the mains take over. The galleries in the carbs are very small and even after i cleaned them they were still blocked. that is why i ended up sending them away to be cleaned. the reving you encounter is a weak mixture in the pilot system, but any tweaking of the screw will not overcome the reving. BTW its 1.5 turns from the bottom. Another fault i have found is the pilot screws snapping off at the bottom due to wear of the brass and hamfisted tighteneing (an interference fit into a conical seat) you can check by completely removing the pilot screws and they should have a really fine needle on the end, if they are "dumpy" ie rounded then the end has snapped off, this has happened on both sets of carbs i have had! the float height is very important:- yamaha say 26.6 +/- 2.5mm using a venier caliper, measure the distance of float arm from the top of the float chamber gasket seat (no gasket) to the top of the float. (the float should be resting on, but not depressing the spring loaded inlet needle) bend the tang to achieve level amont both right and left floats have to read the same. Drewpy
  21. genuine exhausts are almost unobtainable now, but sito are available as well as motad 2 in 1's and MAC in usa. Need to check out cmsl.com for parts and speed sport in usa! as I am not too sure regarding the 360 (might be able to use 400 pistons etc. best tyres are BT45's, the rd boys swear by them. drewpy
  22. sounds like a blockage, do you use an inline petrol filter?
  23. far as i know its to supply enough petrol for the carbs and the way the tank sits on the frame!
  24. drewpy replied to apathetic's topic in Classics
    I don't recommend soaking in solvent as there are rubber bits in the choke mechanism. what you need to do is get them vapour blasted ( for looks) and then ultrasonic cleaned. I use jrs in Uk but you will have to do a google search if your in the USA. these will come out ultra clean and JRS even replaced the parts of the carb with my keyster kit and built it up for me! approx £100 for ultrasonic clean.
