drewpy
Everything posted by drewpy
  1. drewpy replied to screamnz's topic in Classics
    any 34mm carbs should fit except 2 stroke ones (i think they are designed different due to the 2 stroke oil, but don't quote me on this) need to put on a dyno afterwards to get the fueling curve right
  2. drewpy replied to ChrisB's topic in Classics
    Chris, do a search on the forum as there's loads of stuff here. pm me if you are still wanting!
  3. drewpy replied to philyam's topic in Classics
    ho ho ho !if you ever find one NOS good luck!! rare as rocking horse do do's
  4. the engine number indicates an xs650b '74 to 1975 but these had calipers behind the fork leg. The earlier 1972 XS2 had their caliper fitted at the front on the right side (viewed sitting on the bike) a swapped front end due to a collision could have happened in the past.
  5. drewpy replied to apathetic's topic in Classics
    You're running too lean, screw in the air screws on the front of the carbs by equal amounts. If that doesn't help you need to check your connections from carb to cyl head and maybe look at buying new carb inlet rubbers as they crack with age and petrol (gas)
  6. drewpy replied to johnyboy46628's topic in Yamabyss
    should do, both are 34mm mikuni's
  7. drewpy replied to xmastree's topic in Classics
    in usa = 1983 Yamaha XS400K found this on motogrid for you http://www.motogrid.com/pages/parts/viewby...d/2/yamaha.aspx enter the above date etc and the service data there as well as part numbers. it is also known as 12n model which was very popular in Germany, which is where you will see most parts on ebay. http://translate.google.com/translate?hl=e...hl%3Den%26lr%3D uses google translator, you can pick up what they are on about (usually) unless you speak german and then you're quids in ) drewpy
  8. if you do short journeys then the engine oil will not warm up properly and the condensation does not evaporate. I'd recommend changing the oil, warm the engine up, and give it an italian service every now and then!
  9. just keep your eye on the disk offset, and be prepared to shim. xs605's had 2 different brake systems from earlier models to later.
  10. never heard of that VIN all model codes are here http://www.cmsnl.com/faq.php?fq_catid=15 If you are sure thae bike was made 12/80 then the model year is 1980
  11. If you want i'll measure mine with the spacers and then if you measure inside your forks you will get a clearer idea!
  12. drewpy replied to Ride or Die's topic in Classics
    I would have thought £400 - £500 depending on how you sell it
  13. drewpy replied to a post in a topic in Classics
    £55 for shocks, couldn't make 'em for that!!
  14. could be similar to my xs400 clutch in the fact that there is a worm drive under the case and the cable connects via a slotted arm. Either the nipple has broken off or the plastic "worm drive" has sheared
  15. I'm converting my xs400 wheels over to wires with disks, they were fitted to european xs250's and Rd400's (18") and fit straight on. Sr's run an 19" front i think and a 18" rear? if you can get the hubs to fit (i used an SR500 left caliper and mount for dual front disks) then you can get them relaced onto the matching rims. drewpy
  16. the word you want is front brake SHOES!! look on motogrid.com for part numbers
  17. drewpy replied to mankie's topic in Classics
    I have some values you could check with an OHM meter... spark plug cap 10kohms pickup coil 700ohms +/- 20% @ 68'F Coil primary resistance 3 ohms +/- 10%@ 68'F secondary resistance 8.6kohms +/- 20% @ 68'f If the sparks are weak, they def won't fire under compression conditions. make sure battery is fully charged. drewpy
  18. drewpy replied to a post in a topic in Classics
    no problem!
  19. drewpy replied to curdy's topic in Classics
    Powder coat, and you can get it in satin. clip on's if your doing the cafe/clubmans look! (don't forget rear sets)
  20. best get a haynes manual and read that, I did see an xs400 chopper whilst browsing the other day. Unfortunatley I can't remember what the site was called. If I find it I will post. Drewpy
  21. drewpy replied to curdy's topic in Classics
    clubmans comes from the fact that these are raced on the club circuit, so would be stripped down to bare essentials for racing purposes. cafe racers are road bikes and were used to break the "ton" in the sixties, so needed clip on's and rear sets etc.
  22. have you tried sunrise graphics?
  23. drewpy replied to phoebe's topic in Classics
    need to check the counterbalance system as the chains can wear. The problems occur when owners don't change the oil at regular intervals so causing seizures in the top end (and cracking the head as it overheats) never heard of a 750cc version and 4k rev ceiling would mean 50mphish top speed on standard gearing!!!! I don't have one of these bikes, and they were rare in blighty. A few VJMC members have restored one and I would advise joing the american chapter and asking there.
  24. drewpy replied to curdy's topic in Classics
    looks like you would have to paint that exhaust. not sure its worth making a seat, It would be cheaper to buy a glass fibre one already made and modify the frame. The narrow seats are a feature of a cafe racer.
