drewpy
Everything posted by drewpy
  1. drewpy posted a topic in Yamabyss
    Mr Cadbury and Miss Rowntree met on a Double Decker, it was After Eight. She was from Quality Street , he was a Fisherman's Friend. On the way they stopped at a Yorkie Bar, he had a Rum and Butter, she had a Wine Gum. He asked her name, "Polo, I'm the one with the hole" she said. "I'm the one with the nuts," he thought! Then he touched her Milky Way. They checked in to a hotel, and went straight to the bedroom. Mr Cadbury turned out the light for a bit of Black Magic. It wasn't long before he slipped his hand into her Snickers and felt her Cream Egg. He fondled her Flap Jacks then he showed her his Curly Wurly and Tic Tacs. Miss Rowntree wasn't keen to have any Jelly Babies, so she let him take a trip down Bourneville Boulevard via her Party Ring. He was pleased as he always fancied a bit of Fudge. It was a magic moment as she let out a scream of Turkish Delight. When he pulled out, his fun size Mars Bar it felt a bit Crunchie. She wanted more, but he needed Time Out, however, he noticed her Pink Wafers looked very appetizing. He did a Twirl, had a Picnic in her Sherbet Dip and finished off by giving her a Gob Stopper! Unfortunately, Mr Cadbury then had to go home to his wife, Caramel. Sadly,3 days later his Magnum lolly started to drip. It turned out Miss Rowntree had been with Bertie Basset who had Allsorts!!!
  2. take off your spark plug and it should stink of fuel. this will also bore wash your oil and wear your engine quicker.
  3. drewpy replied to HGV's topic in Naked
    Welcome to the forum
  4. drewpy replied to Kishkumen's topic in Classics
    I'd check the earthing lead from engine to battery and also check live connections from battery via starter solinoid to starter. ensure the battery is fully charged. all else fails your starter brushes are worn. Get a manual for the bike, this will pay for itself in no time
  5. Feel the kick lever getting harder, this is when it is on compression. depress the compression lever so the piston goes over TDC. let go of compression lever and jump on the kick start. try different amounts of choke and twist grip when engine cold. No choke hot. could also be flooding the engine and creating a hydraulic lock with the fuel. ie over fuelling the bike
  6. drewpy replied to ndickey's topic in Yamaha Workshop
    contact gaps (if fitted) ignition timing valves adjusting coil parameters check carb on that side all gap info is previously posted, use the search facility
  7. already discussed in this forum. please do a search before posting Q's
  8. some thing like this Item number: 170122928169 will fit, but i don't know about the jetting. Why don't you buy an eliminator and tell us if they work
  9. oil low and frothing at higher revs?
  10. drewpy replied to dragonnoodle's topic in Classics
    I'd start with stock and run on a dyno to get the fuelling curve. then you can optimize the flow with new jets if need be.
  11. drewpy replied to dragonnoodle's topic in Classics
    same thing happened to mine, I got a friend to look at them and he pushed them through from the top. It enlarged the hole but you just screw in the pilot screw in more!
  12. Wow those carbs were gunky!! Mine were no where near as bad and i still had a severe blockage in which you describe. Had to soak over night and use a fuse wire and jiggle till i got compressed air through the bowl. Then i sent off to JRS to have them cleaned. Looking at my manuals, the pilot system can't be fed direct from float chamber as it has a blanking plug over the jet so would seem to come off the starter system!! The fuel filter you have is the same as mine. I thought they had a paper element at the top part!!
  13. drewpy replied to Ride or Die's topic in Classics
    Watch those balancer chains and tensioners, and keep the oil clean as the top end gets starved of oil easily
  14. I just used a small inline paper filter. Just because they are ultrasonically cleaned, doeasn't mean all the crud is out. Some swear by using a carb additive in the petrol tank and that clears out the gunk
  15. drewpy replied to bosco's topic in Yamaha Workshop
    on my xs400 the timing marks are called RF for right LF for left. The LT/RT etc is for the valve timing. just a thought
  16. http://www.cmsnl.com http://www.bikebandit.com http://www.yamahaspares.uk.com/index.html http://www.oldbikebarn.com http://www.nwvintagecycleparts.com/ http://www.hvccycle.com/ http://www.yambits.co.uk/ http://www.motoward.co.uk/ http://216.168.60.165/speedandsportinc/index.tpl http://www.cameron-site.co.uk/nrp/ http://www.sunrisegraphics.co.uk/
  17. yep, pilot jets blocked ( a recurring theme in xs400 threads)
  18. drewpy replied to victor400's topic in Classics
    redwhite is the + feed from ignition swtch and connects to both coils. Grey and orange go to the conacts via condensor. the connector must be faulty or just needs some contact cleaner as they can get verdigri and prevent contact.
  19. drewpy replied to BobC's topic in Naked
    as from an xs400D, custom models have 16" rear wheels, high rise bars, different frames to accomodate a different seat. engines are the same maybe minor diferences in '80 with rubber mounted engine and oil sight glass.
  20. drewpy replied to victor400's topic in Classics
    coil primary resistance = 4 ohms (small wire and ht lead) secondary resistance 9500 ohms (small wire to other small wire) check ht cap not cracked and has continuity from lead
  21. drewpy replied to victor400's topic in Classics
    pilot jet blocked ,also check twin contacts (if fitted) to check timing/gap
  22. either running very weak (check sparkplugs) or your ignition has somehow retarded. don't keep running it like that as you are getting partial seizures ( cutting out), does it run when cooled?
  23. drewpy replied to skullarms's topic in Classics
    try asking here http://www.tr1.de/
  24. I get the same measurments on mine and you should have 34mm carbs which are the same as the 400 so your good to go. A rebuild cost; get a keyster kit from ebay (canadian company) and send the lot off to a ultrasonic cleaner who does carbs (150$ ish)
  25. take measurements and I'll check my 400 ones
