drewpy
Everything posted by drewpy
  1. drewpy replied to OIIIIIIIO's topic in Classics
    xs250's had wires, but also alloys became standard across the 250cc range later. 400's where all cast alloys (bloody heavy ones)
  2. can you post a picure to see what your saying?
  3. super, just like Manchester
  4. drewpy replied to OIIIIIIIO's topic in Classics
    that's the one which came after the xs360 as it has plain wheels rather than painted. if the rear guard is in good nick sell it off as they are rare and can't be bought new. the graphics are similar to the german versions. BTW the square tank versions are designated 2A2 models which are more popular in blighty than the US.
  5. drewpy replied to jrhendryx's topic in Classics
    heres a link for you http://www.classicmechanics.com/
  6. drewpy replied to Harv's topic in Yamaha Workshop
    Harv, New pair on UK ebay 110176653553.
  7. could be worn valve guides/seals letting oil into the bore or worn bore/piston rings. a compression check for the latter and replacement for the former.
  8. drewpy replied to jrhendryx's topic in Classics
    the tx engine had a few teething problems which was "mainly" addressed when they renamed it the xs, so the engine mounts should be the same. motorcycle mechanics has a feature in this months edition which would be worth you buying.(either electronically or mail order)
  9. check pilot screw is 1.5 turns from bottom on each carb. its located on the manifold side in front of the diaphrams on the top (brass screw)
  10. drewpy replied to Harv's topic in Yamaha Workshop
    I think you can but it's better to get new, as coils break down over time. Mine were starting to heat up and drip wax out of them. there are some here : http://www.motorcycle-ignition.com/motorcycle_coils.htm but are out of stock at the mo'. just need to make sure that the are for conact assisted ignition as opposed to electronic ignition types which are very different.
  11. A trick i was told, was to pull back the brake lever and tie it up and leave a few days. Any air bubbles trapped, will work their way to the reservoir. This worked on my friends cbx550F when he could not get pressure.
  12. need to check your ignition coils next: off the top of my head: 4ohms and 9k ohms (+/-20% @ 20'C) for secondary and primary, these should be the readings you are looking for. The coils could also break down with running, Mine did that. Also check your battery is charged and charging at 14.5 volts. did you check that the tips of the pilot needles hav'nt broken off in the carb body? If you take one out, they should have a really sharp needle. Both mine had broken off in the carb body and the spare set were the same.
  13. Just had some kids over from Tanzania to our scout night. The local school raised money to bring them over, as the teachers who went over on hols last year were so moved. These kids have nothing, I was so moved by their selflessness and eagerness to please. They came over in a T-shirt and a pair of trousers as that's all they owned. people donated shoes and socks for them and we all moan about not having this and that. It certainly makes you think. even the poorest people here have a lot more than these kids do. we are on this world to make things better for everyone, the selffish can go to Hell!!
  14. Nice bike, what's your next project?
  15. no idea mate, need to contact megacams and then let us all know. I didn't get one as its a bit far to send and havn't got the dosh yet
  16. Hi Peeps, been sorting through my CD's and I've come across parts lists from the SOHC '77 to the DOHC '83 models. I've found an upload site and don't know how long it keeps the file for so, get downloading http://www.megafileupload.com/en/file/1143...0-1977-pdf.html http://www.megafileupload.com/en/file/1144...0-1978-pdf.html http://www.megafileupload.com/en/file/1144...0-1979-pdf.html http://www.megafileupload.com/en/file/1144...0-1981-pdf.html http://www.megafileupload.com/en/file/1145...0-1982-pdf.html http://www.megafileupload.com/en/file/1145...0-1983-pdf.html
  17. you should speak to the wife
  18. could try here; http://www.motorradlack.de/ I suggest using an on-line translator if you don't spraken ze deutch
  19. no problem, do a forum search for online manuals as I must have listed them a few times Drewpy
  20. should just fire right up on first kick! mine does (on half choke in UK summer) why don't you get a manual and have a go tuning it yourself as its pretty easy and you'll get a lot more enjoyment from your bike! If any timing etc is wrong It'll be a bugger to start, whats the power like and how smooth is the engine? get a compression check .
  21. the VJMC helps with that sort of thing. Its best to conact them!
  22. have you tried sirrius online NRP carbs motoward Jim Patch 01935 881817
  23. try here: http://www.repairmanualclub.com/
