drewpy
Everything posted by drewpy
  1. Item number: 270174897888 BIN $44
  2. He He. want some battered frogs legs... I think they are going cheep cheep!!!
  3. Hi and welcome, the only manuel's i know of are in spain You can try hayes manual as they have all the same bikes covered in the series. (ie 250, 360, 400cc's) drewpy
  4. final bump
  5. drewpy replied to bullet172's topic in Naked
    an old chain and some diesel. if you can handle it, acid.
  6. I'lll be there 20th. I'll say Hi if I can find you
  7. drewpy replied to c spanner's topic in General
    My prayers are with you at this difficult time. try to look back at the happy times together and try and talk to people in the same situation. The Samaritons are only a phone call away!!
  8. Super show and its being extended with a grand prix arena, off road sections and wall of death ( I belive Mervin is taking his RD round that!!) great ride out down the A roads from rainy city through Cheshire. http://www.classicbikeshows.com/
  9. very nice, good resto. going to Stafford next weekend? they now have an off road section
  10. Looks like your having fun, like the unusual styling
  11. tune up the bike first, ignition timing, valve gaps, compression check and new spark plugs. then get back to us if it still plays silly buggers. ps check out motorcycle mechanics october issue (UK), they have a feature on the tx/xs500. come on england!!!
  12. Its the polymers in the oil with synths, your not supposed to use full synth. sounds like you are getting some clutch slip and it will get worse as the cork on the clutch starts to go as they are not designed with synth in mind!! your choice of course I wonder if an outer bearing seal is becomming brittle and when cold becames harder? maybe a crank/camshaft seal if it is revs dependant. A trick is to use a long screwdriver and listen like a stethescope for the loudest part.
  13. check out my free parts lists upload on the forum. then you can search each year to find the same part #, but the drum has a notch on the forks, whereas the disk has mounting holes for the caliper. you would also need front forks! Ditto for the 400 head the 250 and 400 def share the same layout but 250 has more meat and smaller valves. drewpy ps the "alloy" wheels weigh a ton, that's why i converted mine to 250 wires at great expense. (worth it though)
  14. AARRHH you used synthetic with a wet clutch. that noise could be the clutch slipping as the oil is too slippy. what's your acceleration like? You need at the most semi synth,
  15. drewpy replied to Woody1975's topic in Classics
    Hi and Welcome, ebay is far the best source and there are speed sport in usa who seem to have some hard to find parts (and you pay for it)it was TX up to 74 then xs after that to a slightly redesigned engine.
  16. fuel mate, could be diaphram probs in the pet cock
  17. this may help, from motogrid web site
  18. Silly Billy, you need to look at it with one eye, half closed and infected with late stages of conjunctivitus. Then it gets into perspective!!!
  19. I'm sorry to break this,but i found some "hidden code" on the photograph. This is what it really is like .................
  20. blummin' 'eck man. A chippy tea is the best meal in the world. its also the name of a song by the Lancashire hot pots, listen here; http://www.myspace.com/thelancashirehotpots it also explains whats in it innit'
  21. Its possible or the diaphram in the petcock is damaged causing leaks. you can get rebuild kts. To by-pass that issue: run some tubing from a container of gas (petrol) and place it higher than the carbs, suck on the pipe and let the fuel run down the pipe and quickly push the fuel pipe onton the carb intake. let the spilt gas evaporate and try starting the bike up and see if that helps. I do that to balance my carbs with the tank off! do this at your own risk!!!!!!!!!!!BTW
  22. make sure they are multi cored or you won't get your plug caps on.
  23. scaramanga had a twin nipple on his left chest. you can see them on a James Bond film Ask him
  24. drewpy replied to OIIIIIIIO's topic in Classics
    yes, but it would make mine rarer and worth even more
  25. try squirting some easy start in the left carb, and if it kicks the engine you have fuel starvation (sticking float needle) or a massive air leak. usually the right carb has the vacuum take off, i'm sure yamaha would have done it on the left if they could as it would have saved ££'s on fuel tubing building so many 1000's of bikes. did you run the bike on prime which bypasses the vacuum system? and cleaned the fuel tap filter?
