drewpy
Everything posted by drewpy
  1. drewpy replied to Bittern's topic in Classics
    you need a haynes manual (plenty on ebay) you just need to take the cam cover off (undoing the bolts in the right order or you will warp the cover) and release the tensioner but first compressing it and lock it using a 2/3mm screw. the blades will lift out (front and back) either side of the cam chain.
  2. drewpy replied to a post in a topic in Naked
    don't know about the levers but Pazzo means idiot in italian!!
  3. Please note that with the arrival of the new "Drive-through" cash point machines in the UK, customers will be able to withdraw cash without leaving their vehicles. To enable users to use this new facility the following procedures have been drawn up. Please read the procedure that applies to your own circumstances (i.e. MALE or FEMALE) and remember them for when you use the machine for the first time. Male Procedure 1 Drive up to the cash machine. 2 Wind down your car window. 3 Insert card into machine and enter PIN 4 Enter amount of cash required and withdraw. 5 Remove card and receipt 6 Drive off Female Procedure 1 Drive up to cash machine 2 Reverse back the required amount to align car window to machine 3 Re-start the stalled engine 4 wind down the window 5 Find handbag, remove all contents on the passenger seat to locate card 6 Locate make-up bag and check make-up in rear view mirror 7 Attempt to insert card into machine 8 Open car door to allow easier access to machine due to its excessive distance from the car 9 Insert card 10 Re-insert card the right way up 11 Re-enter handbag to find diary with your PIN written on the inside back page 12 Enter PIN 13 Press cancel and enter correct PIN 14 Enter amount of cash required 15 Re-check make up in rear view mirror 16 Retrieve cash and receipt 17 Empty handbag again to locate purse and place cash inside 18 Place receipt in back of cheque book 19 Check eyelashes in mirror 20 Drive forwards 2 metres 21 Reverse back to cash machine 22 Retrieve card 23 Re-empty hand bag, locate card holder, and place card into the slot provided 24 Restart stalled engine and pull off 25 Drive for 3 to 4 miles 26 Release hand brake
  4. drewpy replied to r1mick's topic in Yamabyss
    wa wa waaaaaa!
  5. maybe this might be the trouble. http://www.xs11.com/tips/repair/repair8.shtml have a look around the site as many issues are common to each model
  6. drewpy replied to Bittern's topic in Classics
    Its automatic, but you need to check the blades on the chain as they wear.
  7. why not try a newtronic system, they replace the pickup and the TCi box. just need to make sure you have a good 12volts. they have been taken over but I can't remember the new name.
  8. bridgestone BT45's are the biz. I have 90/90 x 18 front and 100/90 x 18 rear on an xs400D.
  9. drewpy replied to Bittern's topic in Classics
    I'd get it dynoed first as it may be making 33bhp already (i know the factory states 39hp) get your print out and you have the proof.
  10. here you go... http://www.nwvintagecycleparts.com/search-...amp;search.y=10
  11. tried bike bandit, old bike barn, speed and sport, motogrid?
  12. could be timing makinig it overheat and causing partial seizure or fuel to vapourise!!
  13. ok.... centre - stud hole to hole = 67mm engine side orafice =32mm carb side orafice = 42mm depth = 35mm
  14. on the engine, clutch side, wind in adjuster as per manual then set free play 1 - 2mm at clutch lever if no different:- clutch cable not lubed, incorrectly routed, or it could be frayed inside. for the price, buy a new one. lastly your clutch pushrod could also be bent preventing it returning against the clutch springs.
  15. try taking your fuses out and give them a clean. could be a + coil feed problem.
  16. poss warped plates!!
  17. you have 34mm carbs which should fit the 34mm 400cc intakes. I can measure both circumferences on my spare set if you like? for reassurance. drewpy
  18. he looks exhausted........and limp.
  19. A guy is walking on the street, feeling suicidal after losing his job and divorcing is wife, when suddenly he finds Santa. "Hey Santa! I'm so glad I found you! I would be so happy if you gave me a loving wife and a new job this Christmas!" "Sure thing. You'll have all that you want if you pay a small price...", says Santa before dropping his pants and pointing to his cock. The guy finishes-up and wipes his mouth and Santa asks him "How old are you?" "38, why?" "And at that age you still believe in Santa?"
  20. What do Michael Jackson and Santa Claus have in common? They both leave little boys' bedrooms with empty sacks
  21. http://www.xs11.com/tips/repair/repair24.shtml there you go . I have done it, but your coils are old and will start to fail
  22. drewpy replied to U2ROPA's topic in Classics
    PM mervin on this forum, he has access to rdaircooled site and will be able to help.
  23. Battery knackered, try charging it on an optimate first to see if it will hold a charge.
  24. drewpy replied to motoman21's topic in Naked
    Wale Oil Beef Hooked!!!
  25. they do age and crack. they will need replacing soon, as they will suck in air.
