drewpy
Everything posted by drewpy
  1. youv'e not visited the denziens of Manchester then?, £5 just to get into a pub on sat nite!!
  2. went for £177, just a night on the tiles for you xs360?
  3. I use Millars 20w 50 sports semi-synth. its expensive as it is blended on a small scale. being meant for older engines it works fine with Clutch in oil systems. I have used 10w 40 but found it too thin and tends to get a bit hot.
  4. I've used that company once, and can't fault them, even sending to UK not sure about the carb holders, its the connection to the engine which you need to look at. oil in exhaust, bit of blow back from the gummed up piston rings? which if now ungummed could be ok now! also your valve seal could have hardened and letting oil by pass the seal.
  5. drewpy replied to pbaszxs400's topic in Classics
    Or ride in a groove on the road If you have a custom model, they have longer shocks as they have a 16" rear wheel. you would have to use a standard front end as well to balance the bike (or drop them through the top tree!!
  6. Or the piston rings have ungummed themselves!!! best way to maintain an engine is use it!
  7. you sure you got tdc?, double check by removing the spark plug and holding thumb over hole and turn engine over to the correct timing mark (its not necessarliy TDC either)
  8. not just a pretty face yer know!!! seriously, let us all know how you get on for the benefit of present and future posters!
  9. drewpy replied to jrhendryx's topic in Classics
    youv'e got more luck, my xs400D spring is exactly the same as yours If you go to progressive rate springs, the springs are a bit longer and a little harder to fit as you have to compress the spring more
  10. drewpy replied to dsligh's topic in Classics
    one on UK ebay right now
  11. got nothing from the mags, although there was some mention of lesters in the aircooled RD site but nothing helpful. I know they were standard equipment for triumphs in the seventies so it could be your asking in the wrong forum. try asking in Classic bike forum as there that has a good cross section of bike owners (jap, european and Uk bikes)
  12. there is a similarily afflicted xs500 owner on another thread, when I get home i'll measure my springs for the 400 and see what difference there is.
  13. I wouldn't go over £4 I'd have them if they delivered
  14. beats me and all, I think I did try to test once, but gave up and used the 14.5 DCV at 2500rpm after checking the stator, field coil and rectifier. really there's nothing else except a broken wire in the loom, but my loom was NOS
  15. drewpy replied to jrhendryx's topic in Classics
    cheapskate try motogrid or bikebandit as they have online parts lists
  16. no idea what the manual is, just got it on a cd from ebay, eons ago on my yam service manual for xs400 ( all voltage regs are the same) 1) ohmmeter (0 - 200 ohms) one probe to black wire and one to reg base 10.5+/-2ohms @ 20'C 2) one probe to brown wire and other to green wire 140+/- 10ohm @20'C 3) 14.5 - 15 volts DC at 2500 rpm hope that helps
  17. drewpy replied to jrhendryx's topic in Classics
    if you measure the length and the width of the spring, I'll check mine and we'lll see if they are the same!! Yamaha used parts bins across their model ranges
  18. if you search the forums and put in "xs400 monoshock" there are answers there
  19. lester was a british aftermarket wheel supplier in the 70's, so the wheel could be for anything. being 19" I assume xs650 xs750? I'll look at some old mags to see if i can find any info
  20. drewpy replied to pbaszxs400's topic in Classics
    I've had loads of probs with the tips of the adjuster snapping off by heavy handed butchers. so i have had to drift out the needle tips thus opening up the jet. not had a problem with slow running as the new needles can close up and compensate for the amount of widening hope that helps edit: i hope we are talking about the pilot system situated top front of the carb via the pilot screw!!
  21. drewpy replied to jrhendryx's topic in Classics
    could be 33, 34 or 35mm which is measured out side diameter. it has nothing to do with the springs, you need to take one out to measure it just done a google search and this came up http://xs500.org/XS500e.htm
  22. ignition works by providing 12v to primary and an earth, contacts/cdi then interupts the earth but the current now has nowhere to go except to secondary and then jump the gap of the spark plug as this is the easiest path. maybe you can interupt the earth to create a spark at the plug. ( not too long as the coil heats up) i would suspect either a faulty earth on the cdi or the cdi itself.
  23. I get a screeching noise when I start my bike up!....its usually next door neigbours complaining its 7am sunday morning seriously, sounds like the starter gear is starting to wear, you can buy kits from granby's. there are no tappets in an SR it uses an OHC configeration, is the rattle a tapping noise which rises with the revs? or is it a general clatter (thinking clutch basket!) losing power could be any thing but I'm inclined to think its a fuel supply problem either tak full of crud and/or carb getting partially blocked every now and then
  24. you need to cap the inlet stubs as it will draw too much air. these use mikuni Constant Velocity carbs, which use diaphrams to raise or lower the main needle via the engine induction which gives a smoother response. the throttle cable merely opens a butterfly valve in the carb. you use the stubs on the rubber inlets to balance the carbs
  25. I think its called a "cobalt drill bit" which is well 'ard and did my 3 disks and is still going.
