drewpy
Everything posted by drewpy
  1. drewpy replied to CadXS's topic in Classics
    xs250 with wires on ebay now 120236111177
  2. the bars puts more weight on the front which pushes the steering into corners, that's why it will corner better.
  3. why upgrade carbs? to tune a bike it needs heads gas flowed, free flow exhaust, hotter cams and then you might consider changing carb to maybe a slide carb which gives a snappier response for racing purposes. usually to go faster, it depends where you ride. around town lower gearing at the expense of top speed, higher top speed fit a fairing and may be raise gearing slightly. twisties, get decent tyres to maintain higher speeds on corners (depending on rider ability) I have seen off modern 400's on the lanes of cheshire riding round the out side of racing leather clad pocket rockets, but i reckon it was rider experience that held them back! straight roads it was harder but it was all part of the fun! different again for track racing.
  4. drewpy replied to xs360's topic in Classics
    i think the 250 crank mouths are smaller, and final drive sprocket different. that's about it for the bottom end.
  5. drewpy replied to CadXS's topic in Classics
    I lurrve Pontefract cakes
  6. drewpy replied to Goff's topic in General
    TWENTY FIVE!! TUT TUT
  7. drewpy replied to CadXS's topic in Classics
    you need xs250 wire wheels, check on ebay as they come up all the time, they are disk front but also disk rear. custom styles will have disk front and drum rear. if you do get a drum front you will need the fork lowers as well. ditto the rear as you will need a bracket to stop the brake plate rotating. try german ebay as well, and get the hubs sent as you can get rims and spokes from central wheel birmingham. check out the garage for mine wires on a 400
  8. are you UK or USA based? prob best to use the 360 brake and throttle cable
  9. don't just rely on ebay. Yamaha dealers still have stock in. BTW there is a Yamaha official conversion for the oil filter. it lets you use an oil filter for an XJ600. you'll have to google it as thats all I know
  10. drewpy replied to bralkan's topic in Classics
    if the srew part of the actuating mechanism has come off, there are two ways of putting it back in. there is a ball bearing, but it is in the screw mechanism. i think that there is another but at the clutch end between the clutch mushroom and the rod. the cover will be tensioned slightly when you first put it on but not in any major way. the adjustment is merely taking up the slack between mech and rod. it should be obvious if the screw mech is off as it doesn't follow the line of the clutch cable.
  11. drewpy replied to xs360's topic in Classics
    you need a tubeless wheel and a tubeless tire to work, XS400 wheels are tubed.
  12. been there done that! the only way is to push them out from the top, both mine and my friend carbs did it! slightly upsets tickover , but not much as new needles will compensate. make sure you don't over tighten them and certainly not without springs fitted.
  13. bike batteries arn't the most durable commodities
  14. drewpy replied to bralkan's topic in Classics
    its do-able, don't bash the cyl head on the fins if it is stuck. soak some diesel oil down the stud holes and leave to soak. corrosion is worse at the front studs. use the sequence for undoing the cam cover and head nuts. make sure you get all the gasket material off the faces, but don't scrape with a metal object, use shaped wood. don't forget the black O rings above and the red O rings under the cylinder bore replace all gaskets with new, but don't use any gasket goo on the top cam over as you open the gap for the camshaft bearing surface and drop oil pressure. clean the barrels BEFORE starting work as shit will get into the bottom end. put rags under the cyl head when lifting to stop more shit getting in. give the cam cap a good polish when off the bike. (might as well when its off) don't forget to lap your valves and keep all springs and valves in the same set. use sandwich bags and LABEL everything. don't be tempted to smooth the inlets or exhaust unless your a tuner. a rough bore surface promotes better gas flow than smooth. you can use a dremel with wire attachment to get into the nooks and crannies whilst decoking. its said that solvol the piston crown afterwards stops the carbon building up on them. check the rings for breakages but dont remove them if you don't need to as they snap dead easy. take your time and enjoy the experience, don't try and complete it to a dead line as you tend to cut corners.
  15. the XS voltage regs are usually mechanical and switched by contacts (replaced by electronic in 1980). due to this and the bikes age I'm not suprised these go. the suzuki GS series was different in that the 3 phase alternator powered separate electrical items rather than "pooling" the current. So that 1 phase ran only the lighting system, 1 for battery and the other for the rest. because the lights wern't on all the time that part of the alternator got really hot and blew reg/recifier. the key was to keep your lights on !!!!
  16. drewpy replied to xs360's topic in Classics
    xs's have 18" front and rear except customs and their derivitives which have 16" rear but higher profile tyres. 19" is for xs650,750, 850, 1100's to convert to twin disk; there is a plastic blanking plug on the other side of the hub (spoke or alloy) which is pulled off (it will probably break off in bits) there you will find the drilled holes for another disk. you also need an SR500 caliper and caliper mount (it says "L" on it for left) SR's have their single disk on the opposite side as our bikes. and you need an XS1100 brake master cylinder to push more fluid to counteract the extra brake piston. Keep the wires they are much nicer and I spent over £400 converting mine last year with flanged ally rim and stainless spokes. my wires are significantly lighter than the original aloys.
  17. drewpy replied to xs360's topic in Classics
    that's a wheely good deal!!! Got 2 sets me-self
  18. drewpy posted a topic in Yamabyss
    what's black and bushy and sits on a C*nt? Alistar Darling's eyebrows!!!
  19. thought it was blue!!!
  20. drewpy replied to cafe-J's topic in Classics
    Looking clean, get that seat, cos the one on there don't sit (sic!) right. a few here are building cafe's and flat trackers and discussions are as how to hide the battery and gubbins to clean the lines of the bike. keep us abreast of your project as it happens!!
  21. 12v alarm batteries are looking the best fit
  22. then you will have to call yourself "bratkan" then!! they do look cool, the way I am going to get that "see through" look is to find a tiny battery to fit where the starter motor is and I also have a reg/rec in 1 unit to put under the tank. I also have a BMW remote master brake cyl which I'm going to mount under the tank and have alloy coils al fresco A la Triumph. this will give me the bare look i want on the handle bars ( the hornbutton will fit like a bar end) no lights, just brake light for MOT
  23. make a nice cafe racer that would!! Like this one? if anyone knows who's this is i'd like to know
  24. Just to give us Brits a heads up, Aldi are selling ultrasonic cleaners for £16, great for glasses, rings, erm.....carb jets, carbs, valves, etc etc they are 600cc and you can just get half a carb body in.
  25. yea we have good fuel over here, but then we pay dearly for it!!! £1.12 a litre
