drewpy
Everything posted by drewpy
  1. 69mm is quoted as standard, so iwould assume you are on standard. the overbores go up in .25mm increments
  2. i'd say high pressure is best to shift the crud. just be careful
  3. that's a good tip Joe, no basket ball needles but plenty of football ones
  4. your not too wrong when you say marbles. the starter drive behind the rotor works by having 3 small dowls which are sprung in towards the crank and are at an angle so they can free run when the starter turns off and the engine fires up. Its these buggers that flat off over time and start to slip. you need to get new dowls and springs from yamaha (you need 3) this relates to the xs400 and I'm sure they are the same for the 500.
  5. LOL I forgot to mention the vaseline
  6. drewpy replied to fenman's topic in General
    very good the guy talking other than hitler was on LEXX a really good sci fi show which got shit in the final 2 series. ( although "Sev" was Fit as F*ck)
  7. drewpy replied to socalyamaha's topic in Classics
    i did'nt, but i suppose you can just to even up what's on the cases
  8. drewpy replied to socalyamaha's topic in Classics
    use acetone to clean both surfaces. Go in extremely thin ( use a syringe and tiny bead , then finger it over the cleaned surfaces)and let both sides skin for a full minute or so, will seal great and still allow the case halves to be easily seperated later
  9. sounds like you got an air leak usually its the rubber manifolds cracking and letting in air, or over tightened to the cylinder, causing warpage. keep and eye on your oil level, it could be a sticky piston ring if it has been stored for any length of time
  10. check out the other thread on this section
  11. cheapest way would be to get a large cardboard box and open it out, then fold in the centre and wrap around the bike from the front, carefully cutting out holes for the headlamp and handlebars etc. Finally finishng off by careful use of sissors and selotape. Make the end into a bat wing shape like a bat-mobile! Add some stickers from the Panini collection range which you can get from newsagents all over Britain, for that extra personal touch. just my take on things
  12. I remeber them , though not quite that way . who remembers the I-spy books?
  13. drewpy replied to Airhead's topic in Yamabyss
    wha wha whaaaaaaaaaaa! I was reading this book today, The History Of Glue. I couldn't put it down.
  14. my mates Gilera does the same (honda engine) till its warm
  15. 1) the starter has only one lead from the cover, this is the positive and goes to the positive jump lead( usually red) 2) the engine is earth or negative, use the clips off the jump lead and open jaws and clip to engine fin (it completes the circuit for the starter motor) 3) attach jump leads to a 12v battery observing correct polarity 4) starter should spin, if it don't its knackered
  16. drewpy replied to mrgus's topic in Yamaha Workshop
    XJ 650 H 1980 = 4K0 off this site http://www.dropbears.com/m/models/yamaha/modelcodes.htm confirm here http://www.vehiclelicence.gov.uk/EvlPortalApp/
  17. drewpy replied to lukey's topic in Naked
    nah! I had a '79 KH125 and it rocked, micron exhaust and metzlers that lasted 2k miles, most fun i had bombing round devon (when i lived there!)
  18. drewpy replied to a post in a topic in Yamabyss
    Poof! and he's gone. good one
  19. thanks for the comments, just clip it to an engine fin, anything with bare metal
  20. correct, and earth to ground on the engine. you canuse a different battery if you want to eliminate the bike battery( like a car one)
  21. you havn't inadvertantly switched off the bike via the kill switch did ya? eh? wobble your keys in the ignition switch in case its not making contact and take out and put back your fuses ensuring all is clean
  22. drewpy replied to a post in a topic in General
    I will be soon, nearly finished the dohc carbs for my sohc engine
  23. drewpy posted a topic in Yamabyss
    what's the difference between maggie thatcher and edwina curry? one fu*ked major the other fu*ked the miners
  24. drewpy replied to Ride or Die's topic in Classics
    nah! it's crap, deregistered xs400 and look every now and then at xs twin group.
  25. not necesarily, by pass the solinoid by getting jump leads and connecting to earth and the fat black lead from you starter motor. if it spins then its not the starter. and i would suspect the solenoid, do you hear buzzing after the "click" or is it quiet? buzzing indicates starter worn, nothing, i would suspect the solenoid
