drewpy
Everything posted by drewpy
  1. when running with charged battery. you should be getting 14.5 volts + across the battery terminals @ 3k revs. if not, your voltage regulator has gone.
  2. it will be engraved on a flat part of the crankcase in an obvious position.
  3. all hail King Merv, the courier King!!!
  4. neither 20w 50 i use millars semi synthetic classicsport oil, never use full synthetic as your clutch will slip!!
  5. that was the mens
  6. if you have just rebuilt the motor it could be that it just needs running a bit. The valves need to bed in, I don't think that swopping the camshaft over (temorarily) would do damage unless you miss-timed the valves thus hitting the piston crown. did you use new valves and ground them in or reuse the old but didn't put back into their original place?
  7. there was a female weightlifter who had an amazing snatch.
  8. Robert Mugabe has won 7 individual Gold Medals at the Olympic Games.
  9. drewpy posted a topic in Yamabyss
    An amateur magician accidentally turns his wife into a settee and his two kids into armchairs. He starts to panic. He tries every trick in book but none work so, in desperation, he decides to take them to hospital. Once at casualty, the magician spends a sleepless night while the medical staff run numerous tests on the unfortunate woman and children. Finally, the head doctor comes out into the corridor to speak to the magician. "How are my family?" he asks worriedly, "are they alright?" The doctor replies, "they're comfortable..."
  10. are the valve gaps adjusted ie shims etc? if the compression is more than 10% down I suspect you would have to tear down to investigate further.
  11. drewpy replied to new2biking's topic in The Bar
    what is the key number, should be a 4 digit one. you might get lucky and a subsciber may be able to cut you one or have a spare!!
  12. cheers for that, I'll give them a go as I work in Bury
  13. Goff, which powder coaters in manchester? I could do with a decent one nearby rather than bingley. I tried chicago powder coaters in stalybridge and they were sh!t, and another in broughton who were too expensive.
  14. I had a z400b, with balancers removed, shake rattle and a little roll!!!
  15. reminds me of a V-Max what is the engine number?
  16. I think its a case of disconnecting electrical connections, then starting with the ignition switch, turn the key, connect something else, turn the key etc. i would start with the starter motor + solinoid first.
  17. mods should post a "sticky" £30 seems steep when you can get a frame and swing arm powder coated in black for £55 at triple S (inc masking and blasting)
  18. drewpy replied to sschering's topic in Classics
    seen some on german ebay, try there!!
  19. not sure about copper. look at this...
  20. drewpy replied to sschering's topic in Classics
    1st 3 numbers on your engine # will do
  21. drewpy replied to sschering's topic in Classics
    we need to know what year and model the xs400 is, there are at least 4 variants over the years!!
  22. you have to strip the carbs down. you can do all the jets ans the carbs would have to be turned over. larger more expensive ones you can immerse the whole carb in it
  23. no problem
  24. sorry mate, should have been more explicit. Mikes xs is a shop http://www.mikesxs.net/mikesxs-tools.php?category_id=7.1 Alternator Rotor Puller - Safely pulls rotor without damaging it. Fits: All 650’s. Part #35-0040 $10.00 USD EA. I think nthat this will do it, need to check thread size with yours
  25. Aktung snell snell!!!
