drewpy
Everything posted by drewpy
  1. drewpy replied to gregu's topic in The Bar
    http://www.motoverse.com/tools/vin/yamaha.asp damn tried it and will only accept 17 digits
  2. unfortunatly the kick only turns the motor over 1 revolution. spray in some carb start and bump start the bike. As its not been running a while I suspect that every thing is gummed up. change the oil and filter first so the engine has a chance to be properly loobed.
  3. replacement turn cancellres are £45 so maybe the owner thew it away. As for the side stand switch, I don't have one and really can't see any problem without one. the gubbins are usually attached inside the side stand bracket!!
  4. you need the following; 1) xs250 wire/disk front end, there is already taps and drillings for a second disk as standard on all xs400/250 wheels 2) Sr500 carrier and caliper ( is marked L on carrier) 3) xs1100 or twin disk xs750/850 master cylinder 4) twin stainless hoses with dual banjo at master cylinder rear 1) swing arm for disk model 2) xs250 disk wire wheel and spacers sell your drum stuff to cafe racers as it has the "period" look
  5. 12r refers to the model number of the bike ( and its associated different parts) mines 2A2 so any part starting with 12R won't fit my bike! hope that helps Oldgit, I'v lost me Intenet explorer now ( bloody virus)
  6. drewpy replied to sg1's topic in The Bar
    they are modern classics, sweet looker mate
  7. drewpy replied to Skidz's topic in The Bar
    grifs reality works in bristol!!
  8. drewpy replied to a post in a topic in The Bar
    most peeps gp to central wheel components in Brum, I bought my stuff from them but had a local guy build the wheels for £20 each wheel( he also does the manx GP nortons and other race bikes) Wyldes also do rims and spokes. to be honest there is very little difference between them all as they all talk to each other so go for the nearest one. You may want to go to Stafford in October for the jap classic bike show, loads of suppliers there (inc central) and you could pre phone them and take your wheels to be done!!! drewps
  9. I think you need to get back to basics in order to eliminate the cause: fully charged battery (and is charging), valves adjusted; timing adjusted, fuel flows into carbs freely, check all connections (use contact cleaner or ACF50) try pickup coil it should be 700+/- 150 ohms The high revving is due to a weak mixture on pilot jets/air leaks; check by spraying wd40 on the manifolds and listen to the engine revs. make sure the new coils are for electronic ignition, I'm sure that the ratings are different as its in the way the power to the coils are delivered. you really need to get the loom sorted, try a secondhand one off ebay would be the easiest option!!
  10. sounds like coils are heating up and failing. check your manual for the OHM readings
  11. looks specific to the model and has the 12r prefix to confirm this. There are pleanty of xs400 main stands on ebay in USA for you to choose from, also make sure that you have the lugs to fit the stand drewps
  12. Hi, I am answering this from my works comp (naughty, naughty) I have spoke front and rear fitted by myself last year. the hubs are from an xs250 (uk) and are disks front and rear in fact i have the xs1100 setup on the front (god help xs1100 owners coz they aren't super brilliant although I can just lock up the front tyre on a 380lb bike, never mind a 600lb 1100!) don't expect a quick responce from me as my home pc is currently full of viruses.
  13. drewpy replied to brotherflash's topic in Classics
    eh? XS's are parallel twin (250 to 500cc), triples (750 to 850)or four cylinder (1100) http://www.motoverse.com/tools/vin/yamaha.asp for model spec
  14. the weren't even marked just generic ones
  15. drewpy replied to plain old dave's topic in Classics
    down load manual here http://www.files.pioneerx.co.uk/index.php?...torbike%20Files
  16. I'd go for the swing arm bushes and upgrae them to bronze. Easy to check, bike on main stand and wiggle the rear side to side any play more than 1mm! = worn.
  17. I just bought aftermarket ones and they fitted and look the same, so I assume that the ones from Mikes XS will too.
  18. pilot system blocked, do a search as its been talked to death
  19. cool, get that seat done asap and check the seat pan for rust while you are at it!!
  20. its a common mod and actually helps hot gases to escape. used in race cars as well as bikes
  21. drewpy replied to jimbob001's topic in Yamaha Workshop
    sometimes when you are bleeding brakes, the fluid just pushes out and then pulls back in. try getting an assistant to lock off the bleed valve when the lever is pulled in. also tying the brake lever overnight lets the air rise into the resevoir. BTW is the splurge hole unblocked as this prevents the fluid return and causes brakes to stick. My complete method is what chris pearson does (CMM) run a tube from the bleed nipple and wire it into the resevoir then the fliud has a return circuit and is very effective as no air can re-enter the system and any air left, can rise to the resevoir.
  22. I personally would'nt bother. you would need; drill out the blank on the engine, fit a new bigger amp battery, solinoid, starter chain tensioner mount, starter ring gear behind the stator, starter switch, h/duty cabling and chain. drewps
  23. drewpy replied to jrhendryx's topic in Classics
    need to use it, rings will be stuck and to unstick you keep the engine going. carbs will have deposits in them and are a bugger to shift make sure the battery is charged and serrvice the complete engine including timing
  24. yea, I took scouts to lake windermere for a week!! bloody knackered now. xs360c vs xs360-2D no D model that was for the 400 front brake C = disc brake 2D=drum main stand, rear foot rest, starter motor, starter switch flasher self cancelling system fitted on C. 2D =none fitted battery C = 12V, 12Ah. 2D = 12V,7AH 2D serial number starting from 1T6-000101 BTW
