Everything posted by drewpy
Business Meeting Bingo....
Business Meeting Bingo.... 1. Before (or during) your next meeting, seminar, or conference call, prepare yourself by drawing a square. I find that 5″x5″ is a good size. Divide the card into columns-five across and five down. That will give you 25 one-inch blocks. 2. Write one of the following words/phrases in each block: synergy strategic fit core competencies best practice bottom line revisit take that off-line 24/7 out of the loop benchmark value-added proactive win-win think outside the box fast track result-driven empower knowledge base solution touch base mindset client focus paradigm game plan leverage 3. Check off the appropriate block when you hear one of those words/phrases. 4. When you get five blocks horizontally, vertically, or diagonally, stand up and shout “BULLSHIT!”
42" phillips
The wife got me a Philips 42 " for Christmas. What the fuck do I need a screwdriver that big for?
- HAPPY NEW YEAR
My new '78 xs400
their stainless steve, my xs did that as they are single wall pipes. originals were twin walled. Anyhoo to the forum Fol
dynamic crank balancing
thanks I've emailed them Anyone else got somewhere nearer?
calling XS360 owners
oops your right, i was looking at the NOS case when it was upside down thanks for checking!! I now need to get a plug made and seal the case, strange it wasn't already done in the first place!!
- Year
Another thought
one's a bloke, i rekon that's Merv
I have a new xs case (NOS) which I am going to use instead of my currently (porous) one The only concern I have is that there is a machined hole under the case in front right quadrant ( as you sit on the bike) Mine has the casting, but is either had an alloy bung drifted in or it has not been machined out! there is no aparant use for this and is maybe for a future/past mod that didn't materalise with me so far? The reason I'm asking 360 owners is, what do you have there?, is it like my 400 or do you have someting else in its place. Cheers Drewps
anyone know of a decent dynamic crank balancer in the manchester/northwest area of the UK? looking to having it done when I rebuild the engine into new cases in a couple of weeks time drewps
sr125 begining to be a pain
I'd be inclined to leave standard so its easer to sell. cables need to be loobed yearly ( all you readers do that don't you?) you can loob a cable using a funnel and plasticene to seal it and leave overnight, you can use a small cableoiler which uses the power from the wd40 (or whatever) oil spray or you can get a hydraulic cable oiler (£18 from Frost) and these force the oil through in seconds and are great (cos I got one )
- thoughts for ya all
broken crankshaft ???
thought graphite was slippy? maybe put thread lock on your nut (not your head) maybe you could lap in the taper to get max friction using fine valve paste!!!
sounds like you also need to make sure the earthing is sound and not corroded. you would need to undo every terminal and clean using wd40. BTW to the forum
piaggio
- respraying plastics
I did my old kh125 A3 with spray cans and also laquered it to stop any oil/petrol reacting with the paint!!- broken crankshaft ???
does sound like a woodruff key, although they are only there to locate the part, its the taper friction that keeps it on. Maybe a loose bolt causing it to jump- super moto wheels 4 a dt 125 r 2001
central wheel in birmingham wilde in leeds hagon- only owned a R6 1 day and not to happy
If its a hydraulic clutch, it may need bleeding- im a bit batterd
sorry to hear this chop! I know you love that bike all the best for the new year mate- FIRST TIME OWNER
to the forum I love the xs400 sohc, there are only general tips i can give. just don't throw anything away as it invariably is the the part you need 6 months down the line, or someone wants to buy it from you!! the camshaft runs in the head with no bearing surface, so always keep the oil topped up and use the best 20/50 you can get. you can use RD stuff as the bikes chassis are similar and can also use some engine parts (rd400 D shift shaft is one) the bikes are simple beasts get a parts list ( or the online one from motogrid/yamahatopdog/bikebandit) and there are manuals links around the forum (yamagod is the one who has these at the mo') if you get stuck, search the forum first as we have discussed lots of xs400 problems over the year or so. If your still stuck, post in here and you'll get lots of info (good and bad ) drewps- LOL not again
they HAVE to be jokes right? I can't belive peeps would be that thick- merry christmas!!
- CBT
- xs500b carbs
never thought they used Keihn that's usually Honda stuff - respraying plastics
