.jpg.5c05eb7af257e741ca000bd984024429.jpg)
Everything posted by drewpy
YAY! off to north west 200
Mate just booked the ferry from stranraer to belfast today. he has a friend racing in the NW 200 and he has a granny flat for us to crash in. He has also got us in the paddock and the evening soirees. Leaving on the bikes friday 15th comming back sunday late. anyone know of a good route to dumfries other than boring Motorway? Drewps
peopleand pets
:lol: I want to stroke her pussy
Nigeria bikers' vegetable helmets
Motorcyclists in Nigeria have been wearing dried pumpkin shells on their heads to dodge a new law forcing them to wear helmets, authorities say. Officials in the northern city of Kano said they had stopped several riders with "improvised helmets", following this month's introduction of the law. Road safety officials said calabash-wearers would be prosecuted. Thousands of motorbikes have been impounded around the country and taxi motorbike drivers have staged protests. Calabashes are dried pumpkin shells more commonly used to carry liquid. According to the new law, all motorbike drivers and motorbike passengers must wear helmets. Kano Federal Road Safety Commission commander Yusuf Garba told the BBC they were taking a hard line with people found using the improvised helmets. "We are impounding their bikes and want to take them to court so they can explain why they think wearing a calabash is good enough for their safety," he said. Fifty motorbikes had been seized so far in Kano city alone, he added. http://news.bbc.co.uk/1/hi/world/africa/7813418.stm
Rusted Headers
use heat as well. the ally and steel have different expansion qualities and will break the corrosion. if it snaps off, arc weld a nut on it and the heat will also halp to remove. drewps
Aussie Giggle
:lol: bet she felt a right tit
my new ZX6r...
just had a horrible thought, it wasn't Handai driving the car was it?
xs250 engine swap (with larger engine)?
but redo the final gearing ie sprockets as you will be undergeared.
Finally...
way, lets see og wheelying on his DT with a pipe in his mouth having a "condor " moment
my new ZX6r...
I know its painful i had a guy pull right in front of me, luckily i dismounted before the bike hit the car which proptly set on fire (gulp!) broke arm in 2 places and a cracked spine L3 and the lesson I learnt was even if you are in the right you still get punished by being injured!! that's enough of me, hope you are ok mate! the police should be able to tell you where the bike is! Get it back asap as you are totting up parking charges, the greedy bastards it cost me £300.
bike parking
the cheeky git! went to park my bike the other day and some dick got there before me!!!
Paint and decals
if you want a decent paint job, you can't get a fast turnaround as they will be busy!! can't help you with the local painters but sunrise graphics will do your decals. drewps
How to remove needle jet?...and other carb questions
yep its the same with mine, they (yamaha) did sometimes have different jets for each carb, so check you havn't inadvertantly swopped them over if you have those jets. did you take the pet tap completly off as i suspect the diapram is not as efficient in releasing fuel. you can get kits form HVG cycle and mikes xs
Are things looking up?
still putting the engine in the frame
French XS 500
essai Ici part # 94862-09104-00 speed sport ICI
French XS 500
bonjour Julien. to the forum. yes that's O rings, you can purchase O rings from anywhere. all you need is the size!
Leather care
At least it will keep the moths away
sounds like you have a fuel supply problem. is the tap really clear of crud? is there a sucking sound when you open the petrol tap? (breather blocked) could try to rig a temp fuel supply and see if it runs ok. (to eliminate the above problems)
- to wh
I'll bet that Santa Pods Nowt like this --
they still do that on blackpool prom (north) but don't advertise! I saw some tasty supercharged JAP engined bikes faster than the modern stuff. (well is was on methonal ) not been for ages, will have to keep an eye out (it's glass you see)
thats how you change the float height!! keep moving them and they will snap off eventually!!
Will a seat from a xs650 fit a xs400?
not uless you want to weld on new tabs. An xs400 seat fits an xs400
'79 xs400f ignition
stick a multimeter on dc volts across the battery terminals and you should get between 13.5 and 14.5 volts @ 3000rpm. for the charging system to work you NEED a good battery as it excites the field coil to generate the electricity. if after you have a good battery and you can't get the volts, it is usually the voltage regulator as they are electro mechanical in operation. drewps
Hey everyone!
not too far from stafford county show ground, get there in april and see a HUGE classic bike show ( modern ones there too) to the forum
- just rebuilt my engine
1978 yz80
you will need a special tool which are common to all mags. looks some thing like this
