drewpy
Everything posted by drewpy
  1. drewpy replied to Bigjim's topic in Classics
    I wouldn't recommend xs250, 400's are way better. I do like the xs750's though especially in grey!! I know what you mean about the 125, i have a cg125 for the missus and its great fun pootling along watching the scenery. bennelli 254's are nice. and the wetdreams are cheap and plentyful. z400's are naff ( i had one) but the z750 twins look and sound brill!! BTW to the forum
  2. don't know whether to laugh or cry its too bloody close for comfort. Or maybe because I read the daily mail!
  3. try wemoto for tapered or get the numbers from there and try pyramid parts as they are always the cheapest (they deal on ebay as well)
  4. drewpy replied to Brodie's topic in Yamaha Workshop
    miss jean brodie (used to like that programme)
  5. I wouldn't put racing oil in, just go with mineral if you've no choice. I use Millars 20 50 semi sythn for classic engines (£38 gulp!!) I doubt you got a plastic bristle though the pilot sytem within the carb! its a labrynth of turns etc. that's why i recommend ultrasonic. If you look back on some old threads, you will note posters swearing blind that they have cleaned out the carb X many times and still come to the same conclusion that there was still crud in there. I would have thought changing the bulbs would be the easiest option first (why strip down wiring?) some past user prob cou;dn't be arsed to change the bulb and left them blown. if thats not the case, its usually corroded connections/switches) drewps
  6. drewpy replied to mlc's topic in Classics
    saw the fist pic and I thought "very nice" saw the second and WOW. done a great job there. nice paint job too!! (although i prefer the wire wheels)
  7. my brake pedal is slightly below the footrest, that way i can rest my foot on it with out depressing the rear brake!! may be its just the setup, but never had any probs in that dept.
  8. having a bike helps
  9. drewpy posted a topic in Yamabyss
    I was walking through the park and I saw an old guy doing Tai Chi. I watched him for a while, marvelling at his moves. Only when I got closer did I see it was a tramp trying to put on his coat.
  10. drewpy replied to tim68's topic in Classics
    line the tank with POR15, available from www.frost.co.uk £33 inc vat
  11. to the YOC jeff
  12. I would say the rings are gummed up and the bike needs using. best to service the bike which would only take couple of hours (especially the valve gaps) clutch slipping and the throttle cable needs renewing or adjusting near the grip ebay is good , speed sport will have them but it'll cost ya pilot jets are still blocked either get the professionally cleaned or use ultrasonic bath. connection is under the left rear cover its a off white nylon triangle just infront of the chain and behind the oil switch. put new bulbs in!! drewps
  13. drewpy replied to swanny's topic in General
    raleigh chopper
  14. saw that ages ago, nice to revisit though
  15. I would say its the solinoid, just make sure you are getting power from the starter button as they have a habit of coming off and all the connections are good (the smaller wire ones as you have checked the thick ones) drewps
  16. drewpy replied to Follyworks's topic in Classics
    you can take the plates off and renew with new/breaker part, or retap if you think there is room
  17. they did enlarge the hole a bit, but new needles will compensate and I've had no problems!! most carbs will be worn by now anyway, so get the kits
  18. ">" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"> these things are amazing, comming to a city near you
  19. drewpy replied to Goff's topic in Yamabyss
    wel done goff, don't forget to take the baffles out when you take her and a friend?!! (coz you have to share the experience!!)
  20. If you like the song, play it yourself here
  21. could be a bad battery not keeping charge thus affecting the alternator. It happened on mine and took me ages to suss (I even changed the voltage regulator) the battery was only 1 month old. now it charges a peach
  22. Q. yamagod will be along shortly to profer you a manual of sorts (usually!!)
  23. drewpy replied to BillingTZR's topic in Naked
    keep going, you'll get there eventually to the forum
  24. Matt, good ride there ( yes I'm biased) DOHC is a later "euro styled" model from '81 and comes in two flavours 45 BHP or 34 bhp (usa market) this has nothing to do with your SOHC model so be careful. There are also custom, heritage models sharing the same engine but with a different frame and longer forks. Both my carbs had their pilot needles snapped off and I had someone push them through. rebuild kits from here
