drewpy
Everything posted by drewpy
  1. I thought Tag was a game
  2. so the old ones are in the right ball park. let us know how you get on drewps
  3. drewpy replied to moemoe's topic in Classics
    it is poss to open up the speedo. Jeepurz told us how in a previous thread drewps
  4. drewpy replied to Clutch_Whisperer's topic in The Bar
    CW and may the 4th be with you!!
  5. when you tighten the nut underneath. the rubber is compressed and tightens up in the top yolk. just checked mine and I have to give a fairly big tug to get them to move. I wonder if the yolk holes have worn larger due to slack bushes? I'm sure I have a pair in the shed., I'll measure the diameter for you they are 32mm
  6. just got wind of this click on imge for more info
  7. I've bought stuf from yambits and pgm and both are good vendors. yambits is a member of the rd aircooled forum
  8. drewpy replied to peteypops's topic in Classics
    if you don't it going, you can give it to me
  9. Sorry I thought the reference was for head removal to check the valves and rockers etc. checking valve clearances dont need new gaskets drewps
  10. kill switch, unless a related component is wired off the 12v supply to the coil. (red white stripe)
  11. geez, having fun?
  12. glad you got something out of it. I had to do similar things for my (then) part 1 off road test!
  13. its cheaper to get a "top end" gasket kit rather than separate items. then you get everything you need ( or thought you didn't need) don't forget you also need a torque wrench for the head. drewps
  14. I'd say take it with you to a parts store and act daft, you may be in with a chance and nothing to lose!!
  15. drewpy replied to mervin's topic in Yamabyss
    very good
  16. drewpy replied to wild foamy's topic in General
    Foamy, if you have the original you can get one made here
  17. drewpy replied to NathanC's topic in The Bar
    eh up Nathan, to the forum.
  18. what day is uttoxeter?
  19. forgot that one. I'm too busy that weekend and its the last one there a well!!
  20. drewpy replied to hippy's topic in The Bar
    hips post in the workshop section for any mechanical woes you may have drewps
  21. drewpy replied to jron's topic in General
    no-one has mentioned Cof G as this affects how the bike behaves and what you can do with it. you can tighten up a bend by leaning low and forward on the side you are turning and the bike will steer that way better. rossi in the GP today was trying out a different approach by kicking his leg out early to set the bike up for the bend. drewps
  22. drewpy replied to peteypops's topic in Classics
    try fuel in the bore as well, don't know if you drained the carbs before storage, otherwise its a carb strip and clean!!
  23. the procedure is in the manual which you can get in the sticky that yamagod has posted. for the cam tensioner, you will need to lift the head off and it might be a good idea anyway, so you can check valves, rockers for wear etc oil should be ideally on the top line, but between is ok, are you using the correct grade (20w 40 in usa, 20w/50 in uk) and are you checking AFTER just resting the dip sick ontop of the casing (ie not screwed in!) drewps
  24. not running clean, maybe you have an air leak in the manifold. have you tried spraying wd40 over the inlet sto check for airleaks? checked your valve gaps? could also be tensioner blades for the cam chain
  25. I don't do Mways, urmston, Lymm, A50, Little chef, A500, A34 to stafford
