drewpy
Everything posted by drewpy
  1. that's what I thought, scary woooo!!
  2. the 34 mm ones I am assured, will fit not the 38mm!! i know some of our german xs owners have used a delorto carb!
  3. drewpy replied to drewpy's topic in The Bar
    thanks, it was a great weekend and I'd thought i'd share it!!
  4. def fueling, or you got timing completley off. double check the easy stuff first drewps
  5. drewpy replied to dtmf's topic in Classics
    dtmf, looks like your handy with bikes. keep up the good work and let us know how you are getting on drewps
  6. is there a mix up with cut off switch and starter? did you check all the colour connections in the headlamp? is there anything else that runs off the solinoid and is taking power on the wrong side of the actuator, so will only power when the solinoid is energised?
  7. Tom from Buffalo you can get new carbs if your so inclined (not original spec) a company sells the modern mikuni on ebay for xs650's but I'm sure they will jet them for a 400. drewps
  8. he didn't say which 1/2 hour Jim
  9. drewpy replied to wild foamy's topic in The Bar
    seen a few MOOBS as well
  10. why not get a stainless one. I ordered a sump plug from a2a4 fixings, cheap and with an allen socket, its called hex socket pipe screws drewps
  11. if you think its electrical, than its a case of checking all electrical connections including the coils. There may be a ballast resistor in there which is bypassed when the starter is used and reverts back to the ballast resistor in normal operation. If this is faulty or badly earthed, then it could give you the sinmptoms you descibe!! I don't have the DOHC manual but there is one in the sticky I made at the top of this thread drewps
  12. I'd say its an earth problem ie lack of a good earth. check the connections (black)
  13. drewpy replied to mervin's topic in The Bar
    :lol:
  14. drewpy replied to FJ12SP's topic in The Bar
    that is niiice!
  15. drewpy replied to jimmythehat's topic in The Bar
    I belive susan boyle is in your area at the moment , give her a call......
  16. sorry, didn't explain very well.. no, the vaccum pulls a diaphram in the petrol tap, which opens up the fuel flow into the carbs. you said the fuel filter had a rather low level and when you went on to reserve it ran fine!!!
  17. drewpy replied to danielh's topic in The Bar
    Dan, enjoy the forum and don't forget to view all the catagories we have here!! drewps
  18. check the fuel tap bowl for crud, it might be that and the starter forcing the fuel to flow via the vaccum system!!
  19. or wear a bhurka
  20. drewpy replied to dugald's topic in Naked
    if you go that route use a proper motorcycle powder coater like triple s or grifs reality works. they are really not that expensive and do know their stuff. I tried a local powder coater and it came out shit.
  21. lavvy or is that luvvy! nice bike the mirage
  22. eh? get a phot bucket account and upload the picture there. copy the image (IMG) tag in the text box. this will load the picture from photobucket into your posting drewps
  23. drewpy replied to 69jmo's topic in The Bar
    69jmo nice bikes thoses I like the grey ones for some reason. watch those electrics though
  24. drewpy replied to drewpy's topic in The Bar
    no pocheen, just a few "barrels" in the bar and lots of tinnies. I'm still getting over it meself, and I finally manged to start cleaning the bike today. Its had 2 washes so far and I think I will need to strip it down to do it properly.
  25. if they have them in stock (usually don't)
