drewpy
Everything posted by drewpy
  1. ATTENTION ALL ZIMBABWE/MOZAMBIQUE BORDER PATROL AGENTS Be on the lookout for a 1951 Chevy, red with white top - thought to be transporting illegal immigrants. .
  2. as per my reply there is no kit, yer on yer own as this was the info off a bike that was on ebay. you should be able to get the pistons and get it rebored.
  3. OMG!!
  4. drewpy replied to Goff's topic in General
    looks great, Boom is not far from me and £99 for 24 hours, can't beat it vroom vroom!!
  5. you need to buy an optimate type charger, this will keep your battery in top condition. buying a glass mat battery (AKA gel) will pay off too drewps
  6. I'm sure there was another thread about this. need to do a search not done it meself so can't really comment drwps
  7. try the INOX web site the sr250 might be the same as the 500
  8. drewpy replied to drewpy's topic in The Bar
    4 secs for me
  9. should be obvious, the xs400 speedo mirrors the casting on the opp side. the disk has a big hole in the middle to go over the speedo drive!!
  10. invest in a cheap bench grider and get a set of polishing mops. you can do mirror finishes in an hour or so. nice work though, now you have gorilla arms
  11. sounds knackered mate. you shouldn't be able to push it up at all. the run out limit is 0.1mm (0.004in) according to the yam service manual. new head and cam cover ( matched pair) is needed, unless you can line bore them and retro fit bearings.
  12. drewpy posted a topic in The Bar
    I think we need to help Goff with her wedding Tunes for the big day! lets hear your top 5 and bottom 5 top 1) All of my my Love - Led Zeppelin 2) You Shook Me all Night Long – AC/DC 3) Beautiful day - U2 4) Forever - KISS 5) Close Your Eyes Forever - Ozzy Osbourne & Lita Ford bottom 1) paranoid - black sabbath 2) white wedding - billy Idol 3) another one bites the dust - queen 4) heaven knows I'm miserable now - smiths 5) She F*%$ing Hates Me - Puddle of Mudd
  13. not sure i did a step by step, but it is very easy... yam wheel has a cover on opp side of hub and pry this off to reveal the machined holes for another disk. 1) fit another disk 2) you need a left hand early type lower fork part. they have a fitting for another caliper mount 3) use a caliper and mount from an SR500 . these are the same as xs400 right side, but it says left or "L" on it 4) buy 1 longer brake pipe and a double banjo fitting for the master cylinder 5) use master cylinder from an xs750, 850 or XS1100 twin disk bike. I would rebuild it with new seals 6) bleed system for 2 hours and there you have a twin disk set-up drewps
  14. drewpy replied to drewpy's topic in The Bar
    doesn't really break, as bearings take the rotational wear. it would be cheaper to buy a whole bike
  15. drewpy posted a topic in The Bar
    Ebay gone mad. thi part makes it more expensive than the bike HERE
  16. have you checked the gap between camshaft and head/cover? sounds like they are worn, maybe due to worn oil pump not providing enough pressure!!
  17. that'll be foamy in the background
  18. Yep, rear is 2.15 and I have a 4:00 tyre for that, but I needing a couple of rubber bungs tp fill in the rim-lock holes
  19. I'd check out her cream buns first!!
  20. drewpy replied to Wizbit_1's topic in The Bar
    go to www.triple-s.co.uk
  21. roger decosta was a 70's scramble superstar (motocross its called now) he had these amazing boots with chromed shin pads and toe tips on his boots. All the Goths ended up wearing them though just done a google and there's nothing on the guy except a painting, wierd!
  22. no idea, its protecting it at the mo' till its nearly finished ,than I'm going to clean it off!!
  23. done drewps
  24. you can get any thing to fit if you really want it bad. the bigger bikes run 19" on front and 18" on rear I've just put a 3:50 tyre on my flat tracker front and it looks funky chunky!! and on a 1.85 rim
  25. I took the cap off my sparkie to run on 1 cylinder ( for testing) and the bugger zapped me. Me being the easiest way to earth check the caps are screwed on tight and in the HT lead centre. I can touch my leads with the plugs attached and not get a belt.
